01-08-2023, 10:04 PM | #1 |
I'm trying....
WTB: OE Exhaust hanger 3941693/3948683
Hi guys...I'm looking for the exhaust hanger/clamp assembly pictured. As best I can tell the assembly is listed as two separate part numbers (upper and lower) 3941693 and 3948683 respectively.
At this point NOS is probably a pipe dream (pun intended), but who knows what magic the new year may bring. Nevertheless, I would be very happy with a workable/restorable original should any of you have such an animal. Similar clamps were used in the square bodies as well I believe. Net cast. Thanks for any help.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
03-04-2023, 09:38 PM | #2 |
I'm trying....
Re: WTB: OE Exhaust hanger 3941693/3948683
I gotta try. TTT.
03-06-2023, 09:23 AM | #3 |
DND Trucks
Walker made some of the mufflers and hangers for our style trucks when new. Napa may have the old parts book for reference and then you may be able to locate old stock using their inventory nationwide search engine.
03-06-2023, 04:58 PM | #4 |
I'm trying....
That is a good suggestion, thanks for posting...but unfortunately I have reached out to them with no luck.
I'm also on the hunt for some "one nut" 2-1/8" clamps like the ones pictured. I expected them to be easier to find. But coming up zeros on that too. I thought I'd found some on eBay recently (also pictured), but they were too large. If anybody has any ideas on that one, I'd be grateful for any help rendered.
03-06-2023, 11:29 PM | #5 |
Active Member
Some of this stuff must be the same as other GM products. I am searching for 72 big block exhaust hanger pieces. What vehicle was that hanger you pictured used on? You might try dealers that deal in other GM lines.
03-07-2023, 01:09 AM | #6 | |
I'm trying....
The exhaust part numbers are many and superceded several times over in many cases. Clamps are definitely a part for which there are many numbers...and I've tried all the ones I know to try or think to be correct. I am working on a very late 1970 Fremont K20. The pics are of a very original 1971 Fremont K20. Thanks for posting.
