01-16-2023, 07:46 PM | #1 |
Junior Member
1964 GMC parking rear parking brake cables.
Good evening guys and gals!
I have run into an issue while replacing my rear brakes. I ordered the rear parking brake cables but they require the backing plate to have a small hole for the cable to go through but my truck has two brackets, one appears to be made on the cable itself. I found a photo of what mine looks like but it is for an older model truck? I have leaf springs ,not coils in the rear does this make a difference? |
01-16-2023, 08:49 PM | #2 |
Re: 1964 GMC parking rear parking brake cables.
That looks like the ones I just used in an 80’s differential….
01-16-2023, 09:01 PM | #3 |
Junior Member
My truck was stored since 1989 and appears to have the original rear end. I ordered cables from LMC but they attach to the backing plate through a small hole and not the two piece bracket that mine does.I was able to purchase the seals for the brackets from the same vendor though, but no brackets were even listed.
01-17-2023, 02:47 PM | #4 |
Moderator
Think it's been switched out? The rear end.
01-18-2023, 10:47 AM | #5 |
One needs to remember that although the 60s GMCs and Chevys are similar, they are not identical. GMC used Spicer 44 rear ends in the 1/2 ton, and they utilize the cable you have pictured which bolts to the backing plate. I was able to get a replacement from Inline Tubes that was spot on.
01-18-2023, 06:42 PM | #6 |
Junior Member
Thanks MtGMC! I will get with them asap.
1964 GMC 1000 Custom Swb. Fleetside 1955 Pontiac Star chief 1988 Lotus Esprit |
01-18-2023, 06:56 PM | #7 |
Junior Member
01-20-2023, 12:33 PM | #8 |
Junior Member
Well the rear cables are ordered, $60.00 per side! Ouch! Now if I can just find a pair of parking brake strut bars I can finish the brakes and finally get it out of the shop for it’s first wash since 1989!
01-21-2023, 10:19 AM | #9 |
I too bought the Inline cables for my 65 GMC half too, short box. Spot on. Not too many choices out there.
You can get the strut from Bills truck shop, in Ontario, Canada. Good guy to deal with. Page 83 - 84 of this catalog. https://billstruckshop.com/wp-conten...-Sept-2023.pdf |
01-21-2023, 10:25 AM | #10 |
Junior Member
Are the 1964 GMC brake struts the same on a Chevy?
01-21-2023, 01:48 PM | #11 |
No idea.
01-21-2023, 03:39 PM | #12 |
As I earlier posted , I used a set like that, but for an 80’s differential, got them from Rock Auto if I remember correctly, sure wasn’t as much as you got hit for…
03-19-2023, 05:25 PM | #13 |
Junior Member
The rear brake strut bar is not the same on a GMC, my truck has a Dana 44 rear end and the strut bar has a major offset to clear the backing plate. I ordered the one from Bill in Canada and they do not fit.This is the correct strut bar so I am still searching for them.
1964 GMC 1000 Custom Swb. Fleetside 1955 Pontiac Star chief 1988 Lotus Esprit Last edited by Claimchaser; 03-19-2023 at 05:30 PM. |
03-19-2023, 07:39 PM | #14 |
This is the one I use on my 62 Dana 44
OMIX-ADA Emergency Brake Levers 16751.05 For 1972-1978 Jeep CJ5 / CJ6 / CJ7 Dana 44 7.75 x 1.25 x 0.25 inches Spring Crown Automotive Brake Strut Spring - 83504310 Last edited by gmc jr van; 03-19-2023 at 09:24 PM. |
