01-19-2023, 02:50 PM | #1 |
WTB radiator brackets
As you can see by pictures I have an aftermarket radiator and brackets. My shroud is to far from the radiator. My brackets are 6 1/2" long with 3 1/2" on bottom of bracket to hold radiator. I understand there is a shorter version at 5 1/2" long but not sure if it will fit my radiator which is 2 15/16" wide. If someone has the shorter version in God shape let me know. Thanks
01-19-2023, 04:33 PM | #2 |
Re: WTB radiator brackets
I sent you a pm. marko
01-20-2023, 01:01 PM | #3 |
Always on the hunt...
Hey John, we can offer you the shorter version 2/3 core upper hold downs and lower radiator retainer mounting brackets with rubber cushions/pads in OE used for $50. per 8 pc. (qty. 2 upper steel hold downs/qty. 2 lower steel saddles/qty. 4 rubber pads) set or $175. for the full 8 pc. setup in GM NOS, can ship either option to you in NJ. for $11. Lmk, Mel
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our paypal account & info has been changed as of Jan. 2022. Thanks... |
01-20-2023, 05:05 PM | #4 |
Hi Mel
I need nos set rubber cushions up and lower radiator retainer mounting brackets with rubber cushions , Thanks
MY Facebook ( saad_alhajri ) on Instagram
01-20-2023, 06:50 PM | #5 |
I'm not sure they will fit my aluminum radiator so I'm going to attempt to modify mine but thanks
01-20-2023, 08:15 PM | #6 |
I sent u a pm with the measurements you needed. marko
01-21-2023, 02:22 AM | #7 | |
01-21-2023, 02:41 AM | #8 |
I will take it all
PM SEND
01-21-2023, 04:50 AM | #9 |
Okay you got the 8 pc. NOS radiator mount setup, your new combined parts total including the NOS weatherstrip from the other thread has been forwarded on Sat. 01/21. Thanks again, Mel
01-22-2023, 02:31 PM | #10 | |
Active Member
Have you got another set of these??
01-22-2023, 04:22 PM | #11 |
Yes, we can get a GM NOS 8 pc. 2-3 core radiator upper hold down, lower retainer mounting bracket and rubber pad setup headed your way, a total along with info for sending funds has been forwarded Sun. 01/22. Please confirm your shipping address and we'll get the parts ready to go out. Thanks, Mel
01-24-2023, 01:19 AM | #12 |
Your order for the pair of NOS blazer/jimmy door opening seals and the above NOS 8 pc. radiator mount setup has been shipped off, the combined shipment went out via USPS priority on Mon. 01/23 and the expected delivery day (NY. 11413) is this Thu. 01/26. Thanks again for your order and repeat business, let me know if we can help with any other 67-72 parts needs, Mel
01-24-2023, 01:25 AM | #13 |
The 8 pc. NOS 2-3 core radiator bracket and rubber pad setup is under way, your package went out via USPS priority on Mon. 01/23 and the expected delivery day is this Thu. 01/26. Thanks again for your order and repeat business, let me know if we can help with any other 67-72 parts needs, Mel
