01-29-2023, 09:57 PM | #1 |
Door Glass on a 61
I plan to replace the door glass I have with new glass. I see the kits of 4 tinted windows for a couple hundred dollars.
Did anyone try it? Did you have to reuse the old track / metal where the window slides on the rollers / run channel? |
01-30-2023, 08:36 AM | #2 |
Re: Door Glass on a 61
it just depends on how yours is operating. Its a royal PITA.
01-30-2023, 11:16 PM | #3 |
My original glass came loose after 50+ years, but I was able to re use everything. If you can, pull the old glass first, inspect the metal parts, then determine if they are reusable or not. If they aren't heavily rusted, you can just put the new glass in the original metal parts
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-31-2023, 01:15 AM | #4 |
If the glass is framed, you will want to buy new barrel nuts in advance.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
01-31-2023, 11:34 AM | #5 |
