02-13-2023, 04:03 PM | #1 |
Battery Disconnect
I am looking to add a battery disconnect (that I do not have to go under the hood to disconnect) I was thinking of adding the
Painless Performance Remote Master Disconnect Kits 30206. https://www.summitracing.com/parts/PRF-30206 Has anyone installed one of these? How did it work out? Thanks |
02-13-2023, 04:10 PM | #2 |
Re: Battery Disconnect
I use the underhood one but you could buy all of those pieces for half that price. It looks simple enough.
02-13-2023, 04:19 PM | #3 |
Carpe manana
These work well I have a few: https://www.67-72chevytrucks.com/vbo...&postcount=257
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-13-2023, 04:41 PM | #4 |
02-13-2023, 04:43 PM | #5 | |
02-13-2023, 05:18 PM | #6 | |
NAPA --ST81--about 35.00 minus a discount if you have an account https://www.napaonline.com/en/p/ECHST81 Just installed one in my Toyota over the weekend. I had to make new battery cables anyways. Still have to wire in the button somewhere. It doesn't disconnect the battery completely, but isolates the starter to a possible hidden switch. Last edited by kwmech; 02-13-2023 at 05:29 PM. |
02-13-2023, 08:27 PM | #7 | |
02-13-2023, 08:30 PM | #8 |
You don't need a latching solenoid. That's a Ford starter solenoid. You need a push on/push off SPST switch or even just a SPST toggle switch.
02-13-2023, 09:18 PM | #9 |
70+ ( Old Skool Club )
Had my local electronics guy that does stereo and remote starter installs put a kill switch in my 72. No buttons to push or any special wiring showing. Just do something and you can start the truck and if u don't do it the truck will never start.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-14-2023, 08:18 AM | #10 |
Its my understanding that using a regular solenoid will have a small drain on the battery where a latching solenoid will not because it uses a magnet. possible I misunderstood. At times my truck sits for months without starting because I travel alot for work. I typically just disconnect the battery but was looking for something that did not require going under the hood in case my wife or son need to move it while I am away.
02-14-2023, 08:19 AM | #11 |
I am not looking for a "kill switch" my MSD Box already has one. I am looking for a Battery Disconnect similar to what would be on a RV Motorhome.
02-14-2023, 10:53 AM | #12 | |
There is a 30204 model available on Amazon I will check it out..
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
02-14-2023, 01:01 PM | #13 |
I put one of these on the side of my battery tray.
https://www.autozone.com/starting-ch...-150/32369_0_0 Ran battery cable to a binding post. From binding post I ran to starter and to the 150a circuit breaker. I then connected all accessories and the factory fuseable link to the switched side of the breaker. I discovered after doing this, my LS swap harness picks up power at the starter. At least I can quickly disconnect power to all of the factory wiring and other accessories. Just not the starter and engine computer. |
02-14-2023, 01:07 PM | #14 |
>>Its my understanding that using a regular solenoid will have a small drain on the battery <<
A regular ford type solenoid would not have current draw when not energized, but requires 8-10 Amps to energize. That means an extra 10 Amp draw on the charging system all the time you are driving. Not using a latching solenoid would be a bad idea.
'67 GMC 2500, 292, 4spd, AC |
02-14-2023, 02:17 PM | #15 |
I wired in a Moroso 74102 battery disconnect switch. Very heavy duty. I mounted in on the front frame rail where I can easily reach it by reaching under the truck, but it's not obvious to passers by.
02-14-2023, 03:06 PM | #16 | |
02-14-2023, 04:06 PM | #17 |
Post Whore
You don't want to use the common Ford starter solenoid for a remote disconnect. The coil windings are not rated for continuous operation. Continuous duty rated solenoids are often referred to as golf cart relays. The look similar but are made differently. Cole Hersee is a good choice for them.
https://www.colehersee.com.au/produc...duty-solenoid/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-14-2023, 04:42 PM | #18 |
Why over think this ? What about just a switch in-line to the distributor ? Mount it in a place underneath the dash….
71 C-20 07 Magnum RT AWD |
02-14-2023, 04:48 PM | #19 | |
Unfortunately, it's not on purpose and I don't always know what the "something" is. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-15-2023, 10:39 AM | #20 | |
I'm not a big fan of all your power going through a solenoid all the time. I would much rather have a disconnect like the MOROSO one shown which is probably a rebranded Cole Hersee. A 2484-16 that you can buy on Amazon for $40 will handle 800A surge (for starting) and 175A continuous. M28402 is marine grade and will withstand outdoor mounting and a few more amps. It's like $80 on Amazon. The marine ones at least are still made in USA. Mount it through a fenderwell if you don't want to open the hood, but I would just mount it underhood.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-15-2023, 10:54 AM | #21 |
02-15-2023, 04:11 PM | #22 |
02-15-2023, 05:40 PM | #23 |
i understand what you are trying to do and i think a disconnect on frame rail would work.
just like 540ChevyC20 did
1971 K5 CST Blazer 1951 -3100 5 window short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
02-16-2023, 12:20 PM | #24 |
OP Above suggestions may or may not cover your need as you have indicated in subsequent post. What is the need for battery disconnect? Do you have an untraceable draw? Security? Good disconnects used on race cars do fine and have a second circuit to ground the alternator for protection should the switch be opened while engine is running. This avoids alternator diode damage while engine runs down and alternator stops spinning. https://www.pegasusautoracing.com/gr...pID=SWITCHBATT
02-16-2023, 03:04 PM | #25 | |
I have had many different race cars and am well aware of all the different switches that have been suggested. Those switches just do not fit the need that I am looking for. I posted the Painless Performance Remote Master Disconnect Kits 30206 as it seemed to be what I was looking for and was curious if anyone had used it before. |
