Old 02-15-2023, 09:57 PM   #1
tim71
tim71's Avatar
Electrical Part Lot
For sale is a lot consisting of electrical parts. Included is:
- new never used 8mm spark plug wires with 90 degree plug boots and 90 degree distributor boots...cut and crimp to custom lengths (crimper included)
-set of Taylor straight distributor boots
-4 used battery cables very good cond...pos top mount 52", pos side mount 46", neg top mount 72", neg side mount 26"
-starter switch with pigtail
-headlight switch
-2 underhood wiring harnesses...both are front lighting, horn, alternator, volt reg and on to fender junction box. One harness is very clean with all plugs intact but not for gauges. Second harness is missing a couple plus and needs cleaned up. Harness two is for gauges as it has the ammeter wire with the 3 amp fuses. This ammeter wire could be worked in to harness 1 to complete a very clean gauge harness.
$75 shipped to lower 48. I want to sell as a lot and not split apart.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 02-16-2023, 09:02 AM   #2
angusmac
New Member
Re: Electrical Part Lot
PM sent
angusmac is offline   Reply With Quote
Old 02-16-2023, 07:43 PM   #3
tim71
tim71's Avatar
Wiring lot sold to Angusmac.
Old 02-17-2023, 12:03 PM   #4
tim71
tim71's Avatar
Item shipped. Sent you a PM with tracking info. Thanks, Tim
