Will stock crossmember work with this swap?
Getting ready to drop a 6.0/4L80E combo into our 1969 that originally had a BB396/TH400 combo. I am using the Holley Blackheart motor mounts, which is supposed to postion the back of the bellhousing in the stock location. I have heard that the stock crossmember can be used, but I am not sure if it requires it to be moved, or the mounting holes redrilled, or???? What rxperiences have you guys haved?
Re: Will stock crossmember work with this swap?
If you plan on running headers, you might think about running a new crossmember with the humps already in place so you do not have to fight going under the crossmember.
Planning on running some Speed Engineering Headers. Hadn't heard of that issue in the oast. That's a bummer. Have a suggestion for an inexpensive one. I like the Blackheart one, but that price is out of the budget right now.
I have Speed Engineering on mine. They seem to fit nice and they are 304 SS. I think I paid $300? They make a couple different styles. I think they are designed in USA and made overseas. They beat a manifold by a long shot.
#5 | |
I meant my question to be asking about a crossmember options other than the Blackheart crossmember. It is out of my budget right now. Sorry about the confusion. |
You might check out Speedway Motors for a universal street rod type trans cross member.
They come in different drops and can be cut to widths as needed. |
#7 | |
