02-22-2023, 11:27 AM | #1 |
Will this fuel system work?
I'm installing an LQ4 into my '79 C10 with a Holley Terminator X. Are there any issues with this plan?
Evan B. |
02-22-2023, 11:32 AM | #2 |
Post Whore
Re: Will this fuel system work?
you should be good ,
i used all -6 on mine, no issues there just make sure your pump can supply the pressure, i used a inline pump not sure on the aeromotive,cant look it up here, but i used a vett filter reg on mine been working for a lot of yrs now
02-22-2023, 11:58 AM | #3 | |
Evan B. |
02-22-2023, 12:06 PM | #4 |
Also, should I be running a filter between the in-tank pump and the regulator, or between the regulator and the fuel rails, or both?
Evan B. |
02-22-2023, 12:16 PM | #5 |
Post Whore
yeah, im at work and have limited internet access, so i get blocked from seeing it
im running a fliter between the tank and the pump,my pumps inline, then my reg has a built in filter in your case i think between the reg and the fuel rails would be good enough
02-22-2023, 12:54 PM | #6 |
I just came across this diagram on the Aeromotive website. Seems to be what I'm trying to do.
Evan B. |
02-22-2023, 02:06 PM | #7 |
Post Whore
thatll work..!!
02-22-2023, 05:47 PM | #8 |
On my LS swaps I use the C5 FFR. -6 SS lines. They used to be $50-$60. Now they are over $100 for a GM or Wix. That Aeromotive regulator is a bit more expensive but it should never need replacing.
I ran -6/C5 FFR on a LS2 sleeved and stroked to 427 cubes. RWHP 490. Never had fuel issues. I've used Tank's Inc tanks on two LS swaps. I used Walbro 255 pumps supplied by Tanks. Because I'm paranoid I do have a spare 255 pump that I've had for 10 years and never used. Good luck with your swap. |
02-23-2023, 01:05 AM | #9 |
Maybe look into a pwm deadhead system. Newer technology with oem parts. Lots of benefeits over a return type system. Overall cost will be about the same. https://www.vaporworx.com/
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
