03-02-2023, 08:28 PM | #1 |
Changed out my starter today(3 bolt starter L6 250ci - Weird noise once engine starts
I've been searching old threads but can't seem to find the exact problem I seem to be having.
The truck starts and engages perfectly but once the truck is running, theres a kind of squeal/metal clanging that goes on for a few seconds then stops. Sounds like it's coming from the starter but by the time I get over to that side to stick my ears near it, the noise stops. I've started it about 6-8 times with the new starter and each time the noise doesn't happen for as long. I'm guessing I need to shim the starter out but how do you shim a 3 bolt bell housing style starter. I'm guessing the starter gear is in too deep and getting hung up before it finally gets sucked back in? Anyone had this same problem, what did you do to fix it?
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
03-02-2023, 08:54 PM | #2 | |
The Older Generation
Re: Changed out my starter today(3 bolt starter L6 250ci - Weird noise once engine st
Yup, bendix is not releasing. That would be hard on the starter to keep starting it that way. I don't have any suggestions on shimming that starter because I have never had that problem with an inline. Hopefully others will chime in on this.... LockDoc
03-02-2023, 10:34 PM | #3 |
First thing I'd try is stretching the solenoid return spring. Remove the Starter, and then remove the solenoid by removing the screw that attaches the starter windings to the bottom post on the solenoid. Remove the 2 screws holding the solenoid to the bendix housing. Give the solenoid a slight twist and it will come free. You'll find the spring wrapped around the solenoid plunger.. Stretch the spring about an inch and put everything back together.. If the bendix still hangs up after the engine starts -- take the starter back and get another one.
03-02-2023, 11:05 PM | #4 |
Additionally, you might make sure the tin Flywheel Dust Shield is firmly secured to the bellhousing. On my 292. I have to pull the front flat plate to mount the 3 Starter bolts.
Make sure you put it back correctly and that the tin parts are not interfering with the clutch action. BTDT. Also a lot easier than rebuilding the starter and/or solenoid.
03-03-2023, 11:00 AM | #5 | |
03-03-2023, 11:02 AM | #6 | |
03-03-2023, 01:40 PM | #7 | |
You many not even need to stretch it much, just get the solenoid off and make sure nothing is binding or rubbing. I'd say get the spring out of the old one and see how it feels when you check out the one on the new starter. That's the nice thing about the Inline, easy access to the starter. |
03-03-2023, 02:20 PM | #8 |
OP
If you just bought the starter, just take it back. Not worth the hassle of "fixing" a new starter.....nor should you have to |
03-03-2023, 02:48 PM | #9 | |
It's a gamble I took that didn't pay off in this case lol. Parts prices here in Canada are crazy compared to what you lucky buggers get for options in the US. I'm very jealous! Fixing the starter is really the only option besides buying another one locally and throwing this one out
03-03-2023, 04:10 PM | #10 |
I’ve had the same thing happen on a few starters.
My cure was to spray the bendix with carb and choke cleaner to remove any hard dried grease and then a shot of graphite grease to re-lube it. Maybe not the best way but worked for me. Now I’ll sit here waiting for all the naysayers to comment! |
03-03-2023, 04:35 PM | #11 |
I've had them get slightly out of place and hit the flywheel after installing a starter. It makes a hell of a racket.
03-03-2023, 04:44 PM | #12 | |
Just came back from a starter repair place and they were awesome. Got 3 universal shims and a new spring to try out. I'll do the lube trick and put in the new spring and shim then cross my fingers!
03-03-2023, 04:46 PM | #13 |
Interesting! I'll take a better look when I'm in there this aft. I think my plate was pretty solid but I didn't really pay much attention to it.
03-03-2023, 04:53 PM | #14 |
OP, didn't see your location so yeah you are in DIY mode.
I think you will resolve the issue as mentioned with a spring stretch or swap in old one. Once you get it apart clean & lubricate as mentioned also. Then go have a cold "Blue". I married a Canadian so know the drill up there. |
03-04-2023, 12:52 PM | #15 | |
Ok so here's the update..I'm getting sick of sliding under my truck for the past 2 days! lol. I pulled the starter, stretched my spring (the new one didn't push nearly as hard as the one in the reman starter) and added .10 shims then later doubled them for .20. I lubed up all the parts which seemed to be moving nice and smooth before I opened it up. The verdict.. it still does it! When I first started it up it rattled for about 10 seconds straight and I was able to slide under the truck to confirm the sound was coming from the starter. (Its a little nerve racking sliding under a running truck!) I ended up starting and stopping it about 20 times and it slowly seemed to do it less and less to the point where it would rattle for a second then stop or not rattle at all about here and there. The starter sounds great though when engaging and starting which is weird. I also tried holding the key longer than normal when starting and could hear the gear spinning freely on its own once the truck starter so I don't think it's hanging up. The sound to me sounds like something is grinding against the flex plate but I've looked at mine and there's no way, the flywheel is far away and the plate is intact. Weird! Anyway, I'm gonna run it for a few weeks and really take note of how it's acting. Might even swing by the starter shop and get them to listen to see what they think. At least the truck is drivable though!
03-04-2023, 03:51 PM | #16 |
“. Might even swing by the starter shop and get them to listen to see what they think. “
Why not have the starter shop rebuild your old one and reinstall it?
1972 GMC K2500 Super Custom Matt |
03-04-2023, 10:58 PM | #17 | |
For now though I'm gonna drive it the way it is and see how it acts for a while Thanks for all the help boys!
04-25-2023, 09:45 AM | #18 |
Just a quick update, ended up having my original starter rebuilt and put it in. Noise gone! No idea what the issue with the noisy starter was
04-25-2023, 04:09 PM | #19 | |
What did the shop charge for the rebuild? If your noisy starter was assembled or refurbished in the 3rd World, possibly some kid was making a silent protest against starvation wages by dropping in an extra screw as an ''industrial action.''
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-27-2023 at 11:02 AM. |
04-25-2023, 04:12 PM | #20 | |
04-25-2023, 04:16 PM | #21 | |
Good luck.
04-25-2023, 04:39 PM | #22 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-26-2023, 05:28 AM | #23 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I was going to suggest removing the battery wire, the big red one, and use a 16ga jumper wire to activate the bendix gear solenoid. The solenoid is what moves the bendix. By doing this you can set the clearance for the gear to the flywheel. On a three bolt configuration, adding shims to the two bolts nearest the flywheel and no shim on the rear bolt will rock the nose of the starter away from the flywheel. The reverse procedure to close the distance. I dont think you were hearing bendix spring issues, you were hearing a starter dragging on the flywheel. These starters, the aluminum block the bolts go through to be exact, are probably as old as the truck and have been on and off God only knows how many vehicles before a Chinaman rebuilt it. The mating surfaces are worn and the QC for the new castings is questionable at best! Those machined surfaces are critical and the tolerances are most likely never measured. The knurling on starter bolts isnt there for looks, it's there to locate that easily damaged pot metal nose casting. Sometimes the mating surfaces on the engine blocks and bell housings have been damaged or modified. I have never had to shim a starter until recent years and those starter braces have become a near must for the old factory correct boat anchors...By engaging the solenoid with a jumper, you can get under there and measure your clearance, you can visually see how deep or shallow the engagement is. The End
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
