03-05-2023, 09:29 PM | #1 |
switching a 1975/203 to a 1980/205
Hello looking at switching a my 1975 K10 with a 203 to a 1980/205 would there be any issue or should everything bolt up.
Thanks |
03-05-2023, 11:13 PM | #2 |
Re: switching a 1975/203 to a 1980/205
Couple of links for you.
It has been years since I have studied this. Kipps will probably chime in with the Answer Link: https://www.4wheelparts.com/b/advanc...rs/_/N-1z0alil Link: https://torqueking.com/category/1973...transfer-case/
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
03-06-2023, 01:27 AM | #3 |
As long as you have the correct adapter for the swap and maybe the spline sleeve depending on which transmission you have
03-06-2023, 08:48 AM | #4 |
Its a 205 from a 350 going on to my 350 that was mated to the 203. I think they both are 27 spline. Not sure if 32 spline ever made it in a 350
03-06-2023, 09:39 AM | #5 |
Nope, 27 spline only
03-07-2023, 07:58 PM | #6 |
If a 205 doesn't have the ID plate are there any other markings or cast numbers that will help Identify the year etc. Thanks
03-14-2023, 03:10 PM | #7 |
you may need to change driveshaft lengths
