Retro-fit gauges in my 1963 dash.
Here’s my latest project to finish up the new wiring in my 1963 C10. So I thought I’d share my ideas and methods.
I had a “Plain Jane” 1963 idiot light instrument cluster. I decided to install a GPS speedometer. Vendors sell instrument cluster inserts and new gauges. They can be quite costly. I decided to try something new. I like to be creative. I wanted to keep an old-school look of my 1963 instrument cluster without breaking the bank. I purchased a GPS speedometer/tachometer on eBay for under $70 delivered. I spent another $30 on a triple gauge set. The original instrument cluster plexiglass has an old-school design with embossed numbers on the back of the plexiglass. I decided I wanted to keep that look so I cut a hole in the center of the plexiglass for the new speedo/tach. I removed the bezels and glass from the front of the triple gauge set. The triple gauges fit perfectly behind the embossed areas in the plexiglass. I cut holes in the thin black plate that sits behind the factory plexiglass. The pictures tell the rest of the story. I am happy with the results. It took some time and creativity. The pictures don’t show one of the steps I did very well. I bought a very thin piece of plexiglass and used it to cover the area with the black wood grain vinyl so that everything except the center speedo/tach would be under plexiglass. I thought I would share because you never know what you might come up with if you put your mind to it. My truck instrument cluster will not look like any other at the cruise in.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 03-18-2023 at 09:32 PM. |
Re: Retro-fit gauges in my 1963 dash.
More pics
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Even more pics
A few more
The speedometer/tachometer works well and has a high beam indicator and turn signals incorporated on the face. It has a trip meter and odometer too.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 03-18-2023 at 09:33 PM. |
![]() ![]() ![]() Join Date: Jan 2018
I usually cringe a little when I see original clusters being modified because I'm a sucker for the original clusters, but I actually like the way yours turned out. Great job!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Well done. I like the write up. I really like the speedo/tach with the incorporated indicator lights, and the genuine simulated woodgrain is a nice old school touch. Home run I'd say.
Very nice work! And I love the step by step procedures you shared. This is definitely the type of thread that keeps me coming back to this forum.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
Moderator
![]() ![]() Join Date: Aug 2011
Quite ingenious, as usual. What size and maker is the speedo/RPM gauge?
I like your work, I'm also a fan of the original clusters, your cluster is very well made,
I'll keep that in mind for my 2nd cluster that I still have.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
...just another truck junkie..
![]() Join Date: May 2009
Very interesting and well done. That is quite an original view.
Mike "Bear" Shea |
#12 | |
I’ve driven several miles with mine and it detects satellite signals very quickly. Tach is responsive. Good value for the money IMO. https://www.ebay.com/itm/40410449993...mis&media=COPY
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 03-17-2023 at 07:19 PM. |
#13 |
Please note that the only reason for the adhesive vinyl is to hide the embossed speedo numbers (because I switched to a GPS speedo). If your original speedometer still works, then you can just upgrade by adding the triple gauges and the dash would still look very original.
