LMC side fill tank
I bought this tank and have it installed in my 66 C10. There are 3 vent lines. How many vents do I need? LOL !!
How is the best way to terminate theses tubes? LMC said they aren稚 techs or mechanics. I am ususing mechanical fuel pump on my 250 ci engine. All help appreciated Posted via Mobile Device Last edited by rws1012; 03-17-2023 at 03:05 PM. |
![]() Join Date: Sep 2022
Re: LMC side fill tank
Probably designed to accommodate fuel injection with various return and evap lines. For carb use, I'd merge them into a single vent hose.
I capped off the big tube with a rubber vacuum cap. The other two equal sized lines were run to rear stake pockets with a rollover vent cap. If you feed the line down from the stake pocket top you can screw the cap in from the bottom and you'll never see them.
https://www.summitracing.com/parts/TNK-VVR |
#4 | |
Posted via Mobile Device |
