03-22-2023, 12:38 PM | #1 |
Dana 44 Axle Compatibility
Can anyone shed some light on on the compatibility between the open and closed knuckle dana 44 axles? I understand that the carrier and ring and pinion can swap between the axles, but what about the axle shafts, spindles, hubs etc. Are those interchangeable between the different axles as well? The reason I ask, is that I am now having second thoughts on swapping in my open knuckle dana44. I know that it is a better axle, but the deeper that I go into my restoration, the more I want to keep it 100% original as possible. I do want to keep the Spicer big hubs and will go disc brakes but I am starting to think that I want the closed knuckle axle now.
Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
03-22-2023, 03:47 PM | #2 |
Re: Dana 44 Axle Compatibility
I don't think much if anything is swappable other than the gears/carrier....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
03-22-2023, 07:28 PM | #3 |
The axles, hubs and spindles are different
http://67-72chevytrucks.com/vboard/s...d.php?t=567166 http://67-72chevytrucks.com/vboard/s...d.php?t=567022 |
03-22-2023, 07:41 PM | #4 |
Ok, thanks everyone. It looks like it would be way more work that it is worth.
03-22-2023, 11:34 PM | #5 |
You want to go with the closed knuckle with disc? I am opposite, I would rather have an open knuckle with drums. Oh, wait; I did have that. 1970 axles were drum with an open knuckle... a one year axle... don't buy one!
If I were you I would go with a later axle and be happy. Disc with a closed knucke? The only person that's going to know it's a closed knuckle is you. And a few gear heads. These are large production number vehicles anyway. j
White K20 |
03-23-2023, 08:56 AM | #6 | |
Yeah, you are right. I know that it isn't a rare vette or bugatti or anything. I guess my OCD just kicked in when I was out staring at it the other day. LOL I will stay with the open knuckle 44 and just keep the closed knuckle in the back yard for now. Who knows, maybe I will restore it at some point for kicks, but at least I still have it. :-) Clay
03-23-2023, 02:49 PM | #7 | |
Great work, I snooped on your build thread! j
White K20 |
03-23-2023, 03:34 PM | #8 | |
Thanks much! I appreciate it. Yeah, if this was going to be a daily driver, or anything that I would be using to haul anything other than an ice cream cone I would ditch the Rockwell, Eaton, the SM-420, and a bunch of other stuff. But I really wanted something that was like what I drove as a kid so it is really more for Nostalgic reasons that I am keeping a lot of it. The Spicer big hubs for instance was what I had on my very first truck (a 1973 K20), so having them on this one was a must have for me. The same thing with the Rockwell.....I wanted the funky weird shifter for the 4WD just because. Ultimately, I have 2 T-221 transfer cases (I picked one up on FB marketplace for $100) so I should be ok for now. Besides, it is actually kind of fun tearing into it and seeing if I can make it work. I actually just a NOS input shaft drive gear bushing (the last in the country I believe) from Weller Truck Parts (Thank you again to cbeerman). Along with the rebuild kit that I bought so hopefully over a few beers this weekend I will get it all back together and in the chassis. Clay
03-30-2023, 02:55 PM | #9 |
Hey Clay,
For what it’s worth I too am kind of obsessive about closed knuckles on old 4x4’s. While I’m not a paint daubs and matching numbers kind of restorer (my truck is definitely not as it left the factory in 65) whenever I see an old one I always check to see if it still has the original axle in front. To me that’s the difference between an old survivor or just old sheet metal on top of a new truck. While I personally have never had a problem with the performance of 3/4 ton drum brakes, I see you are pretty committed to a disc swap. Because of that I think it would be pretty cool to do a closed knuckle disc conversion. The info and parts are out there and from seeing the quality of your work so far you definitely have the skills. While your era truck is not terribly rare, keep in mind the 420/221 married combo was a one year only thing, and most of that body style were made in the later disc brake years. Also, don’t let anyone tell you the running gear of that truck is unreliable. As someone who has been using this old junk for hard work and play for many decades, I can tell you that is just not true. Anyway, whatever you decide, keep up the good work, do what makes YOU happy, and above all have fun Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
