Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-28-2023, 11:55 PM   #1
Hotcorner
Hotcorner's Avatar
My New Whip
Two-owner 2002 and garage kept all the way. Looks almost new. Front tires are wearing unevenly, so it might need some front end work.
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 03-29-2023, 07:01 AM   #2
Re: My New Whip
Looks clean. Nice find. I may be entering into the Sonoma world soon. I need a li'l go-getter
Old 03-29-2023, 09:08 AM   #3
Hotcorner
Hotcorner's Avatar
Re: My New Whip
Thanks. I’m replacing my car and an old Nissan hardbody with one vehicle, so this made sense for my DD.
1969 GMC K25
Old 04-19-2023, 01:14 PM   #4
Hotcorner
Hotcorner's Avatar
Re: My New Whip
New tires and an alignment. Tires were not cheap. Fortunately, the front end was good to go.
1969 GMC K25
Old 04-28-2023, 01:23 PM   #5
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Re: My New Whip
Those are nice looking tires. And I'll bet they weren't cheap. Tires are expensive but it's the price of safety.
My Corvette was making a bumping noise when you turned the wheel sharply and I thought the worst, but new tires and alignment cured it.
Sharp Blazer!!!
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 04-28-2023, 02:58 PM   #6
Hotcorner
Hotcorner's Avatar
Re: My New Whip
I just replaced the driver door hinge bushings and it was harder than I expected. The detent spring is a SOB to get out even with the tool. Also, the new bushings are fragile and the pins need to be installed carefully rather than just tapped back in without perfect alignment. Pins prelubricated too.
The first time I did it I knocked the pins down with the hammer and busted one of the bushings. Back to O’Reilly I went and you can’t just buy one bushing. Worse yet you have to take both pins back out to replace the broken bushing and jack up the other bushings.
Anyone replace the front crank seal in the 4.3? I noticed that I have some oil leaking at the front of the engine. Going to try to figure it out but the main seal is apparently a common issue on this motor
New stereo is on the way!
1969 GMC K25
Old 04-28-2023, 03:04 PM   #7
Hotcorner
Hotcorner's Avatar
Re: My New Whip
Sharp Blazer!!!
Paul, that’s quite a garage you’ve got!
1969 GMC K25
Old 04-30-2023, 08:45 AM   #8
FleetsidePaul
R.I.P. E.S.L.L.
Re: My New Whip
Thank you. I do have quite a few cars. Too many. I have sort of an addiction to them.
I also have too many ex wives and like the cars they try their best to leave me penniless.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Old 04-30-2023, 09:53 AM   #9
Hotcorner
Hotcorner's Avatar
Re: My New Whip
You and me both! 😂
1969 GMC K25
Old 07-03-2023, 02:15 PM   #10
Hotcorner
Hotcorner's Avatar
Re: My New Whip
Replaced every front suspension component with new. Control arms, ball joints, Pittman arm, idler arm, sway bar bushings and links, tie rod ends, and shocks. I’m still getting a clunking sound over almost any size bump. Any ideas what it might be? About $1200 spent and I am pissed.
1969 GMC K25
Old 08-27-2023, 09:40 PM   #11
Hotcorner
Hotcorner's Avatar
Re: My New Whip
Following up on my last post: it was the freaking hood hinges. There’s a TSB for it. Requires a funky washer to fix it.
TSB 01-08-63-001B
GM Part no. 12383460. Is apparently a common issue and sounds like a broken shock absorber.
1969 GMC K25
