Old 04-11-2023, 09:05 PM   #1
Factory Guy
Factory Guy's Avatar
Is this standard on a 3/4 ton?
In the process of cleaning up my firewall today I got the brake booster off and noticed this huge reinforcement plate attached to the firewall is this standard on a 3/4 ton?
Factory Guy is offline   Reply With Quote
Old 04-11-2023, 09:56 PM   #2
kipps
Re: Is this standard on a 3/4 ton?
As far as I know, every squarebody has that, regardless of 3/4 ton or otherwise.
It serves several purposes. When you step on the brakes or yank on the steering wheel, that reinforcement plate reduces the risk of firewall cracking. Also, it serves as a gutter that detours any water away from the major firewall openings.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 04-12-2023, 08:19 AM   #3
Keith Seymore
Keith Seymore's Avatar
My bad; I thought I was in the '67-72 forum and didn't respond.
Yes - all squares got that.
Also - I like your master cylinder slave. Just like in the assembly plant.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-12-2023, 09:52 AM   #4
kipps
How and when were the brakes bled on the assembly line? Were the brakes fully bled somehow before the body was set in place?
Old 04-12-2023, 11:58 AM   #5
Keith Seymore
Yes.
Brakes were bled immediately after all the lines and m/c were installed. This occurred after frame turnover (frames started out upside down and were flipped after axles were installed - so after the frame was upright at this point) and before engine set.
The master cylinder was "slaved" in position just like the original poster did (only with a re-useable metal fixture). The brakes were filled via an "evac and fill" process, whereby a machine sucked all the air out, and then allowed the fluid to flow in and fill the void. If all goes well, and there are no leaks, you have a complete and functioning hydraulic system at that point.
At the end of that foreman's area a tester was installed to the back of the m/c. It applied line pressure and monitored the force and displacement over a short period of time. If all was OK at the end of the test cycle the inspection ticket was stamped OK. In the event of a failure of any kind the tester would indicate failure and the brakes were repaired and another test attempted.
In any event the brakes were buttoned up and fully functional before body drop.
At body drop the aforementioned slave/fixture was removed and placed on a little cart so it could be trucked back to the m/c install area and reused.
All these photos are of Line 1 (pickup). I ran the corresponding area on Line 2 (Blazer/Suburban) as a summer student/intern, back around 1980. This area also included the frame VIN stamp, noteably.
K
1979-1986
1986 - 2019
Old 04-12-2023, 01:11 PM   #6
Bears63
...just another truck junkie..
Bears63's Avatar
That is fascinating information, Keith. I always enjoy learning things like that.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 04-12-2023, 01:21 PM   #7
mongocanfly
Post Whore
mongocanfly's Avatar
Always so cool to hear Keith's stories..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-12-2023, 05:13 PM   #8
Keith Seymore
One completed truck every minute, bay-bee!
K
1979-1986
1986 - 2019
Old 04-13-2023, 09:00 AM   #9
Factory Guy
I love going through Vehicle assembly plants, so cool to see stuff being built!
Thanks Keith!
Old 04-13-2023, 09:01 AM   #10
Factory Guy
K
Thanks!
Old 04-13-2023, 09:02 AM   #11
Factory Guy
Thanks Everybody!
Old 04-13-2023, 12:11 PM   #12
D13
D13's Avatar
Interesting... in the B car plant we used 'flow thru' bleeding. Once everything was connected the fill unit pushed fluid thru the system as the chassis moved down the line. As it neared body drop the bleeders were progressively closed, the unit recorded it holding pressure, then backed off and filled the reservoir. I don't recall a slave unit but then that particular area never caused me an issue in the 2 years I worked in that plant.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
