04-20-2023, 09:36 PM | #1 |
Any folks with Magneto experience?
I have had a Vertex magneto rebuilt and cleaned. I've now installed it and a new wiring harness, complete with a kill switch for the mag, (Joe Hunt did the rebuild). I also purchased from them the Magneto Tach Converter, since I'll be running a newer electronic tach.
Has anyone used this box from Hunt for this purpose? I have downloaded the wiring diagram that comes with the converter and I'm still a bit confused. Here is what I think needs to be done..... Red - connect to a 12 volt switch power source Black - connect to vehicle ground Violet - connect to the input of the tach Brown/Black - connect to one side of the kill switch along with a wire to the vehicle ground Brown/Orange - connect to one side of the kill switch along with a wire from the terminal on the magneto Brown/Yellow - No need to use in my situation Does my interpretation of where the last three wires go correct?
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." |
04-20-2023, 10:20 PM | #2 |
Re: Any folks with Magneto experience?
In truth, the only magnitos I have ever been around work wise is on farm tractors built in the 40's and 50's. They were the reason one wire alternators came about as they have no regular ignition system only a kill switch.
I understand the Bubba factor of running a mag but unless you are acutually building a race car that has no battery I don't see the need or trouble with what we have for modern ignition systems now.
04-20-2023, 10:26 PM | #3 | |
To that end, he installed a 1959 Chevy inline six 261 cubic inch rebuilt engine with new pistons and crank. He also did the machine work to install a McCulloch supercharger from a 1959 Studebaker Golden Hawk, The Vertex magneto, and a Hallibrand quick change rear end. None of these make any sense in todays world of "drop in a V8 LS engine with all the doodads" but I'm trying to stay in line with the former owners original plan and keep as many of these unique hot rod oriented items intact and working.
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." Last edited by TX3100Guy; 04-21-2023 at 11:33 AM. |
04-21-2023, 09:35 AM | #4 |
I'm going to move this to the electrical section. You might get more bites there.
04-21-2023, 06:22 PM | #5 |
You might find some answers in this Hamb thread. https://www.jalopyjournal.com/forum/...o-tach.536791/
Be Ware if you have not been around the Hamb before, they do not do modern. it is a traditonal hot rod board that is no billet, no aftermarket independent suspension and a lot of other no discussion on later model stuff.
04-21-2023, 07:22 PM | #6 |
I thought Joe Hunt was no more and not around many years ago. I have a Joe Hunt Magneto on my BB chevy Sanger Flat Bottom, and I had Cerilo redo it probably 25 years ago
Maybe that is a new different shop using Joe Hunts name
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
04-21-2023, 07:24 PM | #7 | |
https://www.huntmagnetos.com/
04-22-2023, 10:07 AM | #8 |
BlahBlahBlah
That engine compartment oozes cool. Neat truck all around and an interesting history. If they used it out on the flats as a push truck they must have really cleaned it up when they got home. Doesnt look to be a salt flat rust bucket.
04-22-2023, 11:24 AM | #9 | |
Even the fenders are in great shape with no sign of rust. The inner fenders were another story. I ended up replacing the drivers side, but in hindsight could have had it blasted and powder coated. The inner on the passenger side was replaced and re-shaped by the previous owner to accommodate the supercharger. The truck is very unique and a bit of a history of hot rodding, which is why I'm trying to stay true to the late previous owners plans, albeit I have done a few things to it for me, such as: - relocated the gas tank to under the bed - installed four wheel power disk brakes - installed a custom designed Ron Davis aluminum radiator - installing a new Autowire wiring harness - installing an Ididit steering column - installing a Vintage radio - installing a Vintage Air AC/heater - ditched the bumpers and installed a rear roll pan (not sure what I'll do upfront) The rest of his vision includes the McCulloch super charger, Vertex magneto, 1959 261 cu/in inline six re-built engine, Hallibrand quick change rear end, etc. Here are a few photo for now -
04-22-2023, 07:08 PM | #10 |
Very cool!
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
04-23-2023, 12:47 PM | #11 |
Msgt USAF Ret
I remember the Joe Hunt magneto use to be the performance mag for Harleys in the 60s.
My 65 Sportster has the stock magneto from HD.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-25-2023, 02:09 PM | #12 |
cool truck and neat pictures. Your interpretation of the wiring diagram is correct too.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
