Old 04-28-2023, 03:04 PM   #1
trkfrmr
TH400 TO 4L80E Conversion
Putting a 99 model 4L80E behind the 355 in my '67,wanting to run metal lines similar to original from transmission to radiator,anyone know a source for the transmission fittings for the screw in lines?All I can find are for AN style,the rear one has a long port.Thanks.
trkfrmr is offline   Reply With Quote
Old 04-28-2023, 04:06 PM   #2
Accelo
Accelo's Avatar
Re: TH400 TO 4L80E Conversion
Only the original style, push in fittings, or the aftermarket ones with the AN connections are available. If they make them I couldn't find them.
Not all 4l60E take the same rear fitting, later ones take the extended ones.
The aftermarket hydraulic tubing flair tool will put the push connection into the tubing if you really want to go steel lines. Does your radiator take 3/8" or 5/16" tubing?
The 4L80E transmission takes 3/8" line. All the early radiators have the 5/16" fittings in them that match up with THM 350, 400 and Powerglides.
Accelo is offline   Reply With Quote
