05-02-2023, 07:38 AM | #1 |
Electric fuel pump for cab tank?
Is it possible to add a fuel pump for the existing behind the seat original fuel tank? I purchased a 383 but I am not looking forward to redoing the whole fuel system over by adding an under the bed tank. Let me know if any of you have done this or is it just not possible. Thanks
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
05-02-2023, 08:40 AM | #2 |
Re: Electric fuel pump for cab tank?
There is someone on here that installed a mazda in tank. You can also do an inline (noisier), but the inline pumps have come a long way.
05-02-2023, 11:55 AM | #3 |
This is what I did for the inline pump that came with the Holley Sniper kit. Its a bit noisy at idle, but who really spends a lot of time at idle.
05-02-2023, 02:36 PM | #4 |
I'm wondering if an in-tank pump would be any noisier than an in-line pump mounted on the frame rail with rubber mounts. Being right behind you a pump in the tank might be pretty noisy.
I have a Holley pump tank module in my Camaro and I can hear it. |
05-02-2023, 02:54 PM | #5 |
In-line (external) pumps are a lot quieter nowadays. I've got one under the cab inside the frame rail.
05-05-2023, 02:21 PM | #6 |
I have an external fuel pump on my 68 c10. It’s a little noisy when first starting but my exhaust drowns out the noise.
Posted via Mobile Device |
05-05-2023, 06:17 PM | #7 |
I bought my '71 in December of 2017.. A previous owner had removed the stock fuel pump and installed an electric fuel pump on the frame rail right under the passenger side seat. He removed all the steel fuel lines and fed fuel through a braided hose..
After about a year of listening to the WHINE of that pump, I removed the pump and all associated parts.. Took me a bit of time, but I fabricated new lines, including the return line, and installed a "3 line" fuel pump.. Best thing I've done for that truck.. If you like listening to an incessant screaming noise, get ready 'cause it's coming with an electric fuel pump... |
05-06-2023, 09:00 AM | #8 |
The Older Generation
I installed a pump out of a 2003 Chevy truck in my original tank. http://67-72chevytrucks.com/vboard/s...=829820&page=6 Post #146, goes through #150. I haven't had it running yet so I don't know how it is going to work. LockDoc
05-06-2023, 08:03 PM | #9 |
Can you install an underhood surge tank instead? https://www.summitracing.com/parts/fif-50006
05-06-2023, 08:57 PM | #10 | |
05-06-2023, 09:43 PM | #11 | |
Thanks. LockDoc
05-07-2023, 01:07 PM | #12 |
LockDoc that was very informative some reason I would like to keep the tank I guess I like it somewhat original looking. I’m pretty sure I’m going to go this route. Thank you!
