05-11-2023, 12:33 PM | #1 |
Who sales pre bent fuel line from fuel pump too carb, info.
I have a Rochester Quadrajet 4 Barrel Carburetor original to my 1967 327 motor. Fuel line size 5/16, I'm trying to get the correct original fit line. The fuel inlet on the carb points straight forward not out and angel to the right, a 45 degree angle. It may be me but I got two wrong ones already on the self.
Thanks NGN NICK Last edited by NGN; 05-11-2023 at 01:11 PM. |
05-11-2023, 01:42 PM | #2 |
Re: Who sales pre bent fuel line from fuel pump too carb, info.
IIRC, only Pontiac Q-Jets have the fuel inlet coming in from the front. I don't ever remember seeing anything but passenger side inlets on Chevys.
I'd have to say the carb you have is not the original. |
05-11-2023, 03:31 PM | #3 |
Actually Buick, Olds & Pontiac had forward entry Q-jets...or at least most of them. Like mentioned, Im not aware of any Chevy with a forward entry. On the Left side of the carb will be the numbers. Check them & you will learn what you (dont) have...not the original carb.
Based on the different placements of the fuel pumps on the BOP's, you will be needing to make your own tube to fit the Chevy. Hopefully you werent too rough on the place that you were trying to buy the tube from. Ha Ha! Lorne |
05-12-2023, 08:55 AM | #4 |
Yep, what they said. Chevy and GMC Q-jet fuel inlets go right, Buick-Olds-Pontiac-Cadillac go straight. Probably going to have to make your own fuel line or get the correct carb.
Even a Holley or 2-bbl style fuel line is more for a side inlet. If your carb is good, you could probably start with a fuel line for a Holley carb and it would get closer than a Q-jet line since it is longer-but still not a working solution. Look at '67-72 Z28 or high horse small block Corvette-but they are also 3/8. Alternatively-you might try to buy a fuel line for a 1968 Cutlass with 350 and it might could be reconfigured. It would be a straight inlet and the fuel pump is on the right.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
05-12-2023, 11:40 AM | #5 |
05-12-2023, 12:40 PM | #6 |
I think I got mine from Inline tube. The vendors differentiate between those for A/C and not, however that's wrong. The difference is whether or not your fuel pump is with a return line, which they claim is for A/C, or without a return line, which they claim is without A/C.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-12-2023, 12:46 PM | #7 | |
Still say an 350/403 Olds fuel line is as close as you are going to get to fitting a front entry Q-jet on a SB Chevy with a bought pre-bent line. And even then I'm not sure you won't have interference with the thermostat housing (and whatever brackets on the passenger side of the engine if you have a/c).
05-12-2023, 01:23 PM | #8 |
Make your own line
LUCKTRUCK |
05-12-2023, 09:54 PM | #9 |
Post Whore
There are rare instances where the forward facing inlet came on GMC trucks. I have also seen Chevrolet boat motors with the forward inlets. But both of those are so rare it's unlikely any aftermarket lines would exist.
Some the late model carbs have the forward facing inlet. The 2 barrel versions of the Qjet should have a fuel line that would work for you. But it may take a trip to the wrecking yard to get one. https://www.classicindustries.com/product/2601.html https://allcarbs.com/product/rochest...-1980-chevy-2/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-13-2023, 12:30 PM | #10 |
^^^. I did this for some other lines. Use a coat hanger and make a template. Measure the length of that template and go buy a 3/8 straight line with fittings on it and a Harbor Freight tube bender. Ifs pretty easy as I never bent up lines but my application worked great. You can add a stress loop somewhere in the new hard line if its too long off the shelf. I got the line at NAPA
05-13-2023, 02:43 PM | #11 |
