Old 05-12-2023, 08:51 PM   #1
65truckowner
65truckowner's Avatar
lower a arm bumpers
Any trick on installing new lower a arm rubber bumpers on a 1966 c10? I cant not get them in
65truckowner is offline   Reply With Quote
Old 05-12-2023, 10:50 PM   #2
Rolland
Re: lower a arm bumpers
I silicone greased the hole in the A arm along with the rubber part that goes in the hole and then put the A arm and bumper in a vise and squeezed it in. Took a little effort but it went in with no damage. Would help to have one person hold everything in place while someone else closes the vise.
Rolland is offline   Reply With Quote
Old 05-12-2023, 11:24 PM   #3
AcampoDave
AcampoDave's Avatar
I used soapy water in a spray bottle and tipped in one side first and the squeezed the other thru.
AcampoDave is offline   Reply With Quote
Old 05-13-2023, 07:07 AM   #4
65truckowner
My complete front end is now together. I am having a hard time pushing down on the bumper. I did spray silicone spray on both pieces.
Old 05-13-2023, 10:32 PM   #5
Rolland
Obviously you can't use a vise now. Maybe you could wrap a nylon cord or something around the small nub and then pull it through, maybe using a pry bar or other tool as leverage. Sounds pretty challenging for sure. Good luck.
Old 05-14-2023, 08:59 AM   #6
65truckowner
Sounds like an idea. I though it would be easy to install. I had it all put back together then decided to replace them to and now here I am.
