68 C10 Longbed
![]() Join Date: Sep 2006
Are 3927019 the correct sway bar bushings?
For a stock 68 C10 pickup? My front bushings are shot and need replacing.
Re: Are 3927019 the correct sway bar bushings?
My GM catalog says its good back to at least '73, but part interchange on both Napa and O'Reilly show that it is good back to '68.
-Scott "If it jams, force it. If it breaks, it needed replacing anyways." Build log coming........eventually. |
68 C10 Longbed
Ok copy, thank you.
I’m digging and seem to see a set for .081 and a set for 1.08 so I’m still a bit uncertain. |
GM shows them as a 1" ID, 2" high. That part number still comes up in the GM electronic catalog.
68 C10 Longbed
Thx, yep I ordered an energy suspension urethane set complete with brackets, I got the 1 1/16”, they should be fine and better than the factory rubber.
