05-17-2023, 09:58 AM | #1 |
C10 Inverter Installs
Anyone install a 12vdc to 120 vac inverter in their truck?
If so, how did you do the install and do you have any photos? Thanks in advance! |
05-17-2023, 10:55 AM | #2 |
Re: C10 Inverter Installs
I didn't install it but I use one all the time with it. I use the clamps on the cables to a hot 12 volts & ground. I plug the charger for my mobility scooter into it & charge the batteries while i'm driving. I don't want to use it while parked as it may run down the truck bat.
Just make Shure you get one to handle the load you are going to put on it. George |
05-18-2023, 08:12 AM | #3 |
What do you want to power? Are you trying to weld or run a compressor or just run a light bulb? How "clean" do you need the power to be? Inverters come in many sizes from tiny to huge (both in physical size and capacity). Some are waterproof, some are not. Kinda depends on what you intend to do with it.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
05-19-2023, 12:42 PM | #4 | |
05-19-2023, 05:25 PM | #5 | |
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
05-21-2023, 11:24 AM | #6 |
I have this one that at one time powered my cabin. Very high quality item. Runs sensitive electronics without worry. It just sits now.
71 C-20 07 Magnum RT AWD |
05-21-2023, 11:50 PM | #7 |
The OP may want to look at the power supply for the laptop for the voltage output. If it's 12V, why convert DC to AC, then back to DC?
05-22-2023, 11:23 AM | #8 | |
We use Eaton/Bussmann inverters at work but they are bigger ones like 1800 or more Watts. Looks like Eaton has a smaller line though. PINV600SW-120 is a 600W one. It was like $168 when I searched. This would be permanently installed, not a cigar lighter plug style. I like to see these as close to the battery as possible to minimize voltage drop and also minimize exposed cables but with the right size wire it could go many places.
05-22-2023, 06:02 PM | #9 | |
I was thinking of using 4 or 6 ga power wires to the primary terminals from the battery. I just want to ensure they are big enough so they do not heat up. |
