Old 06-12-2023, 09:21 PM   #1
iowarust
Steering column help
I am needing a little help on steering column, I had twins and my truck took a back seat to that, kids are getting a little older and it’s time to get back on this panel wagon, thing is, I had the steering colum out and can’t remember what brackets to use to put it back in, do you guys have a couple of installed pictures of the brackets to use for installation? Any help would be appreciated!
iowarust is offline   Reply With Quote
Old 06-12-2023, 10:44 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Steering column help
Hopefully this link will help you out: https://lugnutz65chevystepside.weebl...n-rebuild.html
It's for a 63, but is probably somewhat applicable for whatever year your truck is.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-13-2023, 06:02 AM   #3
iowarust
I can’t seem to find the old column anywhere. I have an aftermarket column to put in it, but don’t have the installation brackets as I think they were with the old column. So if I could see it installed, I’d know what to order, it’s a 1960 panel wagon with a 1980 front clip installed. Also I’m putting in an aftermarket sector with u joints instead of rag joint.
Old 06-14-2023, 01:17 AM   #4
64shortbox
64shortbox's Avatar
Try this link. A lot of good info in it & the additional links.
http://67-72chevytrucks.com/vboard/s...d.php?t=523901
64shortbox is offline   Reply With Quote
Old 07-01-2023, 12:32 PM   #5
Bentbolt
i have most of the brackets. im in iowa
1965 C10 long box laid out on bags
instgram 65see_x
.……………………….. ____
..………________//__l \_____
,,,,,,,/__(O)___//___/__(O)_/
Bentbolt is offline   Reply With Quote
