70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Exterior Mirror question.
Gonna change out my sport mirrors , one I knocked the head off and the other flops. Bought a pair of NOS ones off the parts board here a few years ago so time to install. I think I already know the answer to my question but want to verify and hope I'm wrong. Is there a plate on the inside of the door that mirror screws attach to and is it attached to the door or loose and will fall if I just remove the screws.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Exterior Mirror question.
There is a plate and it will fall if you loosen them all.
20' Daredevil (Ret)
![]() Join Date: May 2003
A few pics I found on the board, to give you an idea what you need.
Yea, thats what I thought and thanks for the pics Stocker and both mirors still on truck so can reuse the plates that are there. Guess window channel and the weather strip the glass goes up into will be changed out at the same time.
Just did this on my 71 GMC , pretty much a 2 guy job too ,jus couldn’t reach it myself
Was thinking okay I could put the window down and then reach through the window and hole in door to hold plate in place then just realized window will probably need to be up so out of te way. Mmmm, wife likes to help sometimes.
Before taking the door apart to get to the plate. I would take some long screws/bolts depending which size/style you have holding the mirror, cut the heads off. Then remove one screw from the mirror and replace it with the longer headless screw. then take second screw out and do the same thing and so on with the third if you need to. Then slide the mirror over the headless screws and then take one out and install the actual mirror screw. Just a thought and it makes it a one-man job.
#8 | |
20' Daredevil (Ret)
A note on the screws. Save your old ones if you can. They have a funny bugle head. I ordered screws from Classic industries. Thread was incorrect and so was the head. Sat too far into the mirror. Called them and they sent another set. Still wrong. Took the old ones and put them in my drill and put a spot of polishing compound on a towel and and buffed the screws. Like new. Just an idea.
#10 | |
Post Whore
![]() Join Date: Feb 2016
If you're a slow learner like me and you loose both plates in the door (In my defense neither plate fell off until I shut the doors and I didn't put 2 and 2 together together after the 2nd clunk when I shut the doors.
![]() Anyway post 257 in the link shows how I got my mirrors installed without help. I only wish I would have thought to put a dab of something sticky on the plate so next time the mirror has to come off the plate will stay put. http://67-72chevytrucks.com/vboard/s...698377&page=11
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 07-17-2023 at 02:33 PM. |
#12 | |
#13 |
![]() ![]() Join Date: Jul 2002
Since I rarely ever have a helper, when I did mine I put some RTV on the plates, use the screw to hold them until it dried, then unscrewed, added mirror and rescrewed it down. Never thought about the long screw thing, wish I would have.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 07-17-2023 at 08:38 AM. |
#14 |
The headless screws can be long as you want. Use long enough screws and they will bind in the hole if and when the plate tries to drop. You also will have something to hold onto to prevent frpm dropping. Longer screws make it so you can hole the mirror away from paint, that I would mask as soon as the mirror is loose enough to slip tape under.
#15 | |
#16 |
Got her done last night. Thanks everyone for the help and ideas.
#17 |
Nice. That's great that this got done!
#18 |
Festus came through again
#19 |
