06-23-2023, 01:51 AM | #1 |
Which Universal Joint do I need?
I swapped out the original rear end in my 1969 C20 Suburban for a rear end out of a 1971 C10 so I could have a 5 lug set up. I thought I had read before doing this that both the C10 and the C20 used the same u-joint at the differential. When I looked at what I have tonight, the u-joint cups on the C20 driveshaft and larger in diameter than the bores in the differential yoke. What u-joint do I need to get to make this setup work?
1969 C20 Suburban 396/TH400, with 2-piece shaft 1971 C10 donor rear end. Motor/trans combo unknown. |
06-23-2023, 07:45 AM | #2 |
Re: Which Universal Joint do I need?
I may be wrong but the 20 uses a 1350 series ujoint the 10 uses a 1310 so you would need a 1350 to 1310 ujoint .
https://www.amazon.com/Spicer-5-460X...29506439&psc=1
