06-25-2023, 09:34 PM | #1 |
70+ ( Old Skool Club )
New look for my Truck
So wanted my tuck to look like the white and red ones in the pictures. I think mission was accomplished as you can see with before and after pictures. Just a 2 1/2 dropped spindle up front with original coil springs and 3 inch drop coil in rear with shock relocators and adjustable panhard bar. Not a lot of curves on my local roads but handles off ramp exits and approaches at pretty good speeds with no sense of the truck breaking loose.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-25-2023, 10:29 PM | #2 |
Re: New look for my Truck
Looks like a match to me, nice. I installed 2.5 drop with factory front coils as well, wasn't that a good time? My 225 lb son sat on the BBC, no body or wheels. Jacked up the lower arm and found the RH rear frame well off the jack stand. Seems I lifted the frame's front some for more better. Made me want 1" drop springs though but I like how it turned out. My SWB has 4" drop leaf springs as well. The combo levels the truck front to back.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-25-2023, 10:29 PM | #3 |
20' Daredevil (Ret)
Nice stance, makes the truck look more solidly planted.
06-25-2023, 11:46 PM | #4 |
I like it! I drove my truck around for many years with the same look and loved it. I thought the improvement in handling was noticeably better also after I did a mild drop. Now I'm curious how much stiffer my ride will be now that I've cut it down to a short bed.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
06-26-2023, 09:04 PM | #5 |
Me like also Already Gone.
My 72’ is lowered slightly also with 235/R70’s. I am thinking of a taller set of tires to fill the wheel wells a tad. How much more? Unsure. It presently drives very smooth, so maybe don’t mess with it? What treads are you running please? Thanks, Sam |
06-26-2023, 09:17 PM | #6 | |
06-27-2023, 07:49 AM | #7 |
It looks right with those wheels
