07-03-2023, 07:08 AM | #1 |
Junior Member
292 in 1966 K10 4X4
Hi
I'm looking for the parts needed to mount a 292 in my 1966 K10. I understand it takes a special offset cross member . If anyone has the parts needed let me know Thanks |
07-03-2023, 10:26 AM | #2 |
Re: 292 in 1966 K10 4X4
You need the right hand , or passenger side frame mount only . No crossmember
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
07-03-2023, 11:23 AM | #3 |
Like he said ^ ^ ^ ^ ^
Its the only thing different from the rest of the inline 6s Motor mount location(s) are different on the passenger side for the 292 than on the 250 and 230 ( which are the same )
dont want to hear excuses, i want to hear solution(s) |
07-03-2023, 12:16 PM | #4 |
Junior Member
Thanks for the reply
Thats for a 4X4 correct |
07-03-2023, 12:42 PM | #5 |
Yes, you are correct. The holes for it should already be in the frame. Unfortunately the 292 perch is unique, you can’t just find the ‘everything else’ part and move it forward
Although it’s a fairly rare part, I and others have found it through the help of others on this forum. Good luck in your search Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
07-03-2023, 03:49 PM | #6 |
Junior Member
So what does it look like can you post a picture ?
07-04-2023, 12:25 AM | #7 |
Aerotruk63 posted a picture of what you are looking for on a stripped out 4x4 frame in the parts for sale section. Check it out.
07-04-2023, 08:52 AM | #8 |
Junior Member
Thanks for the picture
