Old 07-06-2023, 09:15 AM   #1
AlaskaK10
Junior Member
1966 chevy C10 Backup light tapered Mount
Hello
does anyone know where I can get a tapered mount for the backup light on a 66 stepside or for that matter the fenders with the stamped light mount.
AlaskaK10 is offline   Reply With Quote
Old 07-06-2023, 05:01 PM   #2
vetnat
Re: 1966 chevy C10 Backup light tapered Mount
I have been looking for 5+ years. Have not come across any reproductions. I did manage to get a partial NOS back up light kit off ebay. It was for the late 50's trucks - stepside fenders the same. It came with only one of the rubber mounts! I asked around a couple of places that make their own rubber restoration pieces (Steele Rubber, etc), no one was interested in using my one example to make a production run. I was thinking of maybe using my one rubber pad to make a mold, and cast another one. My neighbour thinks it might be easier to carve one out of several thick sheets of rubber. Or, by the time I get around to installing back up lights, maybe I will have found another (or even a set!) rubber pad by then.
I have seen the stepside fenders off 1966 trucks (with the mounting pad stamped in to the metal) for sale more often than I have seen the rubber mounting pads for sale.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 07-06-2023, 07:52 PM   #3
notsolo
notsolo's Avatar
Maybe someone could 3D print these. Mine are off of a 62 panel, hard as a rock...maybe there different on stepside trucks, 3D print and put a thin rubber gasket under them.
notsolo is offline   Reply With Quote
Old 07-06-2023, 09:00 PM   #4
AlaskaK10
Junior Member
Those would work wish I knew how to do 3d printing. I think the idea is great
Old 07-07-2023, 08:48 AM   #5
Backpayne
Do you want this one? I'm going to throw it away. It is tapered.
Backpayne is offline   Reply With Quote
Old 07-07-2023, 09:31 AM   #6
AlaskaK10
Junior Member
I sure would Thank you for the offer
Dan
Old 07-07-2023, 04:02 PM   #7
rideblue00
rideblue00's Avatar
Seems like an obvious question...do other/newer year trucks have something similar?
rideblue00 is offline   Reply With Quote
Old 07-09-2023, 05:10 AM   #8
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
https://photos.app.goo.gl/F28nw8NR3iTHzLmg7
Old 07-12-2023, 03:22 AM   #9
vetnat
That is cool. I did not realize the mounting pad was the same for stepsides and panel trucks.
