07-06-2023, 07:46 PM | #1 |
Junior Member
NP205 Linkage
Hi Everyone
I have a frame with running gear from a 1965 K10. It has a Np205 in it from prior owner. I understand it is a better T case than the Rockwell 221. I am wondering how I would connect the shift linkage. It did not come with one so wondering what I would need. Also any opinions on the install would be appreciated Dan Last edited by AlaskaK10; 07-06-2023 at 07:46 PM. Reason: mistake |
07-06-2023, 07:54 PM | #2 |
Junior Member
Re: NP205 Linkage
More Pictures sorry for the double post
07-06-2023, 08:01 PM | #3 |
Junior Member
Re: NP205 Linkage
I forgot to upload a picture of the existing linkage looks like it must mount to the side of the transmission?
07-07-2023, 12:30 AM | #4 |
Re: NP205 Linkage
My guess is that the shift rod is mangled and the shifter bolts into the lowest bolt hole on the trans in the pic in post #3. It's a big 7/16 or 1/2 shoulder bolt.
07-07-2023, 07:05 AM | #5 |
Junior Member
Re: NP205 Linkage
Would anyone have any idea of the proper shift linkage to make this work or have anything for sale? The other question I had was the mounting of the 205 to the cross member? Is this a proper way to mount it looks like the way the T221 was mounted?
07-07-2023, 08:47 AM | #6 |
Junior Member
Re: NP205 Linkage
Okay more looking at my linkage. It looks like the link arm coming off the 205 goes over the driveshaft and somehow connects to the large bolt on the back pad of the SM420. Has anyone seen this before. How did the rockwell T221 connect? Did it connect to the SM 420 the same way. Surely someone must know
07-07-2023, 09:35 AM | #7 |
Junior Member
Re: NP205 Linkage
I have found a oicture of the original style transfer case Shifter it is attache to a bracket where did it originally hookup? Would I be able to use the original style lever with the 205 or would it require a shifter from a different year like a 70 model that originally had a 205 in it. I have looked at those and they all seem like they are off a married 205 not divorced?
07-08-2023, 07:36 PM | #8 | |
Re: NP205 Linkage
The t-221 lever was factory installed with a bracket that bolted to the drivers side of the transmission and came up through the floor on the driver side of the tranny shift lever. Here is a pic of the t-case and shifter out of the 60-66 assembly manual.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
07-08-2023, 09:43 PM | #9 |
Junior Member
Re: NP205 Linkage
Thanks for the info just what I needed
07-09-2023, 09:21 AM | #10 |
Re: NP205 Linkage
If possible I would twin stick it
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
07-09-2023, 11:25 AM | #11 |
Re: NP205 Linkage
Here's a link just for ideas for fabrication.
If you were to choose the twin stick route. Link: https://jb-custom-fabrication.myshop...5-billet-style
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
