Old 07-13-2023, 03:11 PM   #1
Oberon67
Fel-Pro Carb Base Gasket surfaces not flat
Hi all.
I just ordered a carb-to-manifold gasket from Rock Auto. It wasn't the cheapest one, it's a Fel-Pro. So I get the thing in the mail and look at it, and I see that it's got a hard plastic "grommet" around each bolt hole. Which is fine, except that one of the grommets isn't completely in line with the gasket surface. It's proud on one side by a few thousandths, about the thickness of a piece of notebook paper. That's enough to constitute a vacuum leak.
The gasket is about 5mm thick and made of some hard-resin-impregnated fiber. I may get a piece of fine sandpaper, lay it flat on my table saw, and hone the face of this gasket against the sandpaper until I bring the grommet down flush with the gasket surface. I'm also wondering if application of a little Permatex Aviation sealant would help.
What do y'all think?
Oberon67 is offline   Reply With Quote
Old 07-13-2023, 04:17 PM   #2
Oberon67
Re: Fel-Pro Carb Base Gasket surfaces not flat
Trying to see if I can post a pic...
Old 07-13-2023, 04:21 PM   #3
Oberon67
Old 07-13-2023, 06:17 PM   #4
Dead Parrot
You could try test mounting the gasket and carb and snug things up. The odd ball grommet may self correct under pressure.
Dead Parrot is offline   Reply With Quote
Old 07-13-2023, 08:02 PM   #5
Oberon67
I could clamp that corner in a vise and see if I could self-correct it before I take my carb off.
Old 07-13-2023, 09:40 PM   #6
kwmech
Grommet will center itself up when you install the carb. After you run it through a couple of heat cycles check the hold down bolts again. They have a tendency to loosen up a tad.
Old 07-18-2023, 06:59 AM   #7
Oberon67
As it turns out, my carb isn't a DualJet... it's a VaraJet II.
Same-same with regard to the gasket though. I will likely do the gasket swap this weekend, along with swappage of some old dry vacuum lines.
Jeez this truck came with a lot of smog plumbing. It's an '81... what did I expect?
