07-15-2023, 01:02 PM | #1 |
Front coil spring question
Messed with my front end suspension until it was dark last night, just noticed this morning that my front coil on drivers side looks good, but the bottom edge of coil is not rested against the stop notch in the lower control arm. Is that a big issue? Not really wanting to have to remove all this again. Thanks
07-15-2023, 02:06 PM | #2 |
Re: Front coil spring question
How far away is it?
07-15-2023, 02:14 PM | #3 |
07-15-2023, 03:33 PM | #4 |
<text removed here, cuz I'm an idjit, move along, nothing to see here>
Guessing yours is lowered, because it's not easy to get mine back together with the spring out of the pocket. ;-) Last edited by Rust_never_sleeps; 07-15-2023 at 07:09 PM. Reason: I are an idiot |
07-15-2023, 06:52 PM | #5 |
This has me thinking about mine because I bolted the plate of the upper ball joint to the top side of the upper control arm where the old one was riveted on. Should I have bolted it to the under side?
07-15-2023, 07:01 PM | #6 | |
https://www.lmctruck.com/1967-72-che...-2-wheel-drive Last edited by Rust_never_sleeps; 07-15-2023 at 07:02 PM. Reason: clarity |
07-15-2023, 07:04 PM | #7 | |
07-15-2023, 07:20 PM | #8 |
You'd have to undo the castle nut, pop one of the balljoints out of the spindle,(preferably top) but it's not hard when you've just put it back together. Never mind how I know
07-15-2023, 09:19 PM | #9 |
I thought you might be getting ready to reveal a neat-o trick. :-) I watched a video on youtube where a guy showed how to remove the riveted-on upper ball joint on a C-10, and it was not a 5 minute job. He worked and worked and worked on it. It made me feel better about how I struggled with mine.
07-15-2023, 09:26 PM | #10 |
I got this style of separator from Harbor Freight and was able to use it for the tie rods and the upper ball joint.
The only thing it would not fit is the lower ball joint, so for that I rented the pickle fork separator from the auto parts store. The pickle fork is destructive to the rubber covers, but the one pictured was really neat and easy, makes a loud pop that is a little nerve-wrecking. It made it easier to un-do and re-do, like it seems I have to do on every job, unfortunately. |
07-16-2023, 02:08 AM | #11 | |
07-17-2023, 11:16 AM | #12 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
With the wheels jacked up off the ground, jack on center crossmember. Use a pipe wrench with a cheater bar to rotate the spring in the pocket until it hits the stop. Jacking the wheels off the ground unloads the springs enough to be rotated without taking the ball joint loose...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
