07-17-2023, 12:12 AM | #1 |
What C30 dually wheels are these?
Can anyone tell from the terrible picture what wheels (split ring, 2 piece widow maker, etc.) are on this '68 C30 Cab & Chassis dually? Tires (not sure why it uploaded the tire picture upside down) are 7.5-16LT tube type.
Also, is that an HO72 rear axle? GVW is 10000 lbs. on the door tag. Truck is in CA and I'm in AZ so access is very limited. |
07-17-2023, 12:26 AM | #2 |
Re: What C30 dually wheels are these?
I just found this equally bad picture of the front wheel. Any insights into it's identity would be really helpful. I'm trying to get things set up to get it running again. It's been sitting for a long time...
07-17-2023, 02:42 AM | #3 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Wow, nice truck! 327 is awesome! What trans? And welcome to the Board! I'd guess that would be an HO72 axle...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 07-17-2023 at 02:50 AM. |
07-17-2023, 02:44 AM | #4 |
a 68 C30 with AC? Very nice truck.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
07-17-2023, 07:31 AM | #5 |
Nice truck, and the '68 327 is one of Chevy's best small blocks ever made.
What are you going after? Do you need another matching wheel or just need info on the set on there? All the OEM 16" 8-lug wheels, single or dual, were split rim in this era. up till disc brakes in '71, the studs are 7/16" and use flat back castle type lug nuts, so no spreader plate as found on all '71-ups.
07-17-2023, 10:46 AM | #6 |
07-17-2023, 10:54 AM | #7 | |
07-17-2023, 11:11 AM | #8 |
Budd type. Just the ring. Safe enough if you do it right
07-17-2023, 11:17 AM | #9 |
I thought the split rim type wheels WERE called the widow makers. Came to work one day after school to the station I worked at and saw a hole in the roof above the tire machine. Boss was airing up a tire he had just repaired and bent over to get the tire hammer when the ring let go a punched a hole in the roof. He was pretty shaken up. After that he aired them up with the leg of the lift across the rim
07-17-2023, 11:34 AM | #10 |
Can you post a photo of a front wheel. That almost looks like the split in the middle "widow maker" style from that one photo.
George |
07-17-2023, 12:23 PM | #11 |
Tim-thank you!
kwmech-https://www.youtube.com/watch?v=BuFaNv9y29c&t=663s This explains it pretty well. George-I don't have any better pictures until I go back out in a few months. |
