07-21-2023, 11:59 AM | #1 |
425hp409
Glove Box installation problem
I am finishing up installing Factory AC in my truck. I now have a problem as to installing the glove box. It is an AC box that I had previously installed when I just had a heater. I know that you remove glove boxes from the rear as I did this one. With all the AC components installed I so not see how to install the glove box. I thought, maybe I would have to install the glove box and then the heater box and ac stuff. The problem with this is that I would not be able to get to the top heater box screw and also be able to install all the hoses correctly.
The shop manual states this to replace the heater core: 1. drain Radiator 2. remove heater hoses from core 3. remove the sheet metal nuts from the heater case studs which project to the engine side of the firewall. 4. remove the glove box 5. unplug the relay 6. remove right ball outlet hose 7. then finish removing the heater case After installation of all the heater box and AC hoses the next step is to install the glove box. Is there another style of glove box that I need? Any advice will be appreciated.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
07-21-2023, 12:21 PM | #2 |
Re: Glove Box installation problem
Yes, the glovebox does not fit. But you have to fit it in there anyway. Here's a video.
https://www.youtube.com/watch?v=Q0YG...iAxUA&index=63 Have fun! j
White K20 |
07-21-2023, 12:25 PM | #3 |
I have a non-AC truck, but I removed and installed the glove box through the opening in the dash when I had it out to replace the radio and speaker. It's a tight squeeze but since the glove box is cardboard it is flexible enough to get through the opening.
07-21-2023, 12:39 PM | #4 |
425hp409
Thanks guys, I didn't know if I had to force it, and I do!
