Old 08-05-2023, 08:03 PM   #1
pdxhall
pdxhall's Avatar
bed wood finish
I'm getting ready to finish the new bed wood for my truck. I have planned on using an oil based spar urethane but what about the oil based polyurethane?
I welcome any opinions or advice. The wood is white oak. Thanks
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 08-05-2023, 08:27 PM   #2
Arne
Arne's Avatar
Re: bed wood finish
I used water-based satin spar poly on mine.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 08-05-2023, 11:55 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Re: bed wood finish
I went with a spar urethane. Pretty sure I did that because it's supposed to hold up better to the sun/outdoors and my truck sits outside 24/7
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 08-06-2023, 06:06 AM   #4
1restorick
1restorick's Avatar
Re: bed wood finish
I used a spar urethane from Total Boat company. Ended up applying 9 coats top and bottom to some black walnut boards. It was some significant labor to achieve a glass smooth finish.
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 08-06-2023, 06:16 AM   #5
1restorick
1restorick's Avatar
Re: bed wood finish
Here is a current picture of my truck. I have made many upgrades over the years and love to drive it as well. Replacing the bed wood was a dream for many years. Finally did it.
RED RUMBLE
Owned since 1984
Old 08-07-2023, 12:46 AM   #6
Nevada51
Re: bed wood finish
Wow, impressive finish! A job where you can see the reward pay off...vs trying to unbolt all the original nuts from the original bolts. That is a job in which very few can sympathize with regarding the amount of time required!
I'm on the verge of doing my boards and am going with an oil (Cutek Extreme CD50, assuming the sample pot finish looks ok when I do it in the coming weeks), so a different finish but I didn't want to worry about damaging the finish when I put stuff in the bed, and mine sits out in the elements 24/7.
Nevada51 is offline   Reply With Quote
Old 08-07-2023, 06:57 AM   #7
1restorick
1restorick's Avatar
Re: bed wood finish
Your idea of using Cutex is a good one. The ability to use the bed and to be able to easily recoat the wood is worthwhile. I am afraid to even haul a cardboard box now that my wood is finished like a piece of furniture. Best of luck and please share the results!!
Rick
RED RUMBLE
Owned since 1984
Old 08-11-2023, 10:53 PM   #8
Angrywood
Re: bed wood finish
i did the same thing a couple years back. used boiled linseed oil on the wood first figuring it would get it more life. then stained it and used spar urethane. put a solid coat of carnuba wax on top and after one year i got the dreaded white haze. couldnt find anything on how to deal with that. i eventually lightly sanded it with a green colored scotch brite scour pad. got most of the haze off as i wasnt pressing to hard.
i think what ill do next is use the poppys pantina product on the wood. if that doesnt keep it fresh looking im going to spray it with black paint and be done.
truck sits outside all the time and dont want to replace the wood ever again. that was a pain in the ass...
good luck to you
Angrywood is offline   Reply With Quote
Old 08-14-2023, 02:15 AM   #9
Nevada51
Re: bed wood finish
good luck to you
Is that where your username comes from lol
I hear you. I'm doing mine from scratch, so no bedwood kit. This makes it challenging when you have to makeshift stuff to make the cuts, routs, drill holes, wheel well cut outs etc...and I'm a bit particular about stuff even if it never gets seen by anyone else. So far it is way more work than I had thought...and I haven't even laid one bit of bedwood yet!
Sorry, I've hijacked the original thread. I'll post some pics in a separate thread when I start tackling it in earnest.
Old 08-14-2023, 04:51 PM   #10
Angrywood
Re: bed wood finish
haha no i was angry way before i tackled this. It was alot of work but was fun. peace and quiet doing hands on work. took awhile to do but well worth the accomplishment
