09-08-2023, 05:45 PM | #1 |
1971 K/10 longer front wheel studs?
1971 K/10 front disc brake 6 lug. Need longer threads for thicker hub on aluminum wheels. 7/16 x 20. pic of stock stud. I have searched and have not had any luck. Thanks for any help...........
09-08-2023, 10:15 PM | #2 |
Re: 1971 K/10 longer front wheel studs?
Have you taken a stud in to a good auto parts supplier to match one up? How long is what you have?
09-08-2023, 10:25 PM | #3 |
Who Changed This?
What wheels do you have? In my experience, the nut went far enough into the wheel that it engaged enough of the factory stud threads.
09-09-2023, 12:03 AM | #4 |
Location: Herculaneum MO (20 minutes south of St. Louis
Tell me I'm wrong but I'm pretty sure 71 has 1/2-20 studs, not 7/16-20
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
09-09-2023, 09:56 AM | #5 |
Roadtrip!
I think all of the 6 lug were 7/16 and 5 lug was 1/2. So a K truck would be 7/16
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-09-2023, 10:10 AM | #6 | |
All about them K’s
I’ve never messed with this on a half ton but all I can say is don’t believe everything you may find online. I’ve got a front Dana 60 that I wanted longer studs for. Read from the Front 60 bible on pirate and other sites that you could use a different part number stud that was longer… bought those studs and the knurl was in the wrong spot and the diameter was just a tad too big. This is one of those times where you’ll have to physically compare studs to see what you can find in my opinion.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
09-09-2023, 11:58 AM | #7 |
According to Rockauto the 1971 K10 uses Dorman 619-179. That is 7/16x20 with a .562 knurl and is 1 ¾” long.
Searching for “wheel stud 7/16x20 .562 knurl” I found: JEGS Press-In Wheel Studs 7/16x20 Thread x 2-7/8 Long x .570 Knurl .562-.569 Hole Size 5 Studs Per Package for $13. That knurl is a bit bigger that what you need but should work. (freeze the studs before insertion and use some assembly lube.). Research tells me that you need to have a hole .008-.010” smaller than the knurl. The other problem is these come in a pack of 5 so you would need 3 packs.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
09-09-2023, 11:04 PM | #8 |
Oh darn I wasn't thinking about it being a K truck.
09-09-2023, 08:14 AM | #9 |
Hi Tim, I live on an Island and the only auto parts store couldn't help. The overall length from under the head is 1.750 and needs to be 2in. This is on a friends truck.
09-09-2023, 12:00 PM | #10 |
Tire shops may also have studs...
09-09-2023, 12:32 PM | #11 |
Every time I build a custom front 44 for a chevy I always convert them to a 1/2'' stud. The 7/16 does not really hold up all that well to larger tires and the tire shops crazy tire guys. Blast the lugs on and make sure the torque wrench makes a clicking sound. The conversion stud I use is the Ford stud, and it does require drilling of the rotor and the hub.
