Old 09-11-2023, 05:08 PM   #1
junksaver
Rear Trailering Arm Crossmember
Looking to see what different options people are using for the rear trailering arm crossmember. I'm not looking for anything super fancy. I have a swb frame that I'm redoing for a truck. It will have a 4 or 5 inch drop in the rear. I don't even mind modifying the stock crossmember, but the new ones have gotten so cheap it seams easier to replace it. If you have any pics, brand and price can you post it up. Thanks
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 09-11-2023, 07:37 PM   #2
indymachinist
Re: Rear Trailering Arm Crossmember
What are you trying to achieve? Are you wanting something different than the stock crossmember for a reason?
I am using a stock one with the trailing arm mounts flipped.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 09-11-2023, 08:25 PM   #3
junksaver
I just figured instead of modifying the stock one by flipping the brackets and cutting holes for exhaust, it would be easier to just replace the whole crossmember.
68 4wd Stepside
73 4wd Blazer
