09-14-2023, 07:32 AM | #1 |
Lost my Blower motor speeds
I lost the first two (2) speeds on the blower motor on my 79. Stock setup. Where do I look?
Thanks Chris
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
09-14-2023, 08:44 AM | #2 |
Re: Lost my Blower motor speeds
on the engine side of the firewall between the dryer and the firewall there is a electric plug that has 4 or 5 wires on it, this is how the power gets to your fan motor. It is some sort of resistor as I remember. The yellow wire is the lowest motor speed . Check power to each of these. You should get power to one of these at every speed on your switch. if you don't then switch may be bad if you do then resistor is bad. Doing this from total memory as I am not home to confirm. this info based on my 78 with air. Someone jump in if my info is not correct.
09-14-2023, 10:17 AM | #3 | |
I believe you can still buy a resistor if you need one.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
09-14-2023, 08:43 PM | #4 |
I would check the resistor first, as its easy to get to. you can back probe the plug and see if power is getting thru. the fan switch does go bad sometimes as well but its alot more work to get to.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
09-14-2023, 09:38 PM | #5 |
agree check resistor 1st
09-15-2023, 03:25 AM | #6 |
The resistor 1st (burned) out or plug dirty corroded connectors need cleaning. And you may want to check the Gound clean protect. make sure it got 100% good ground.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
09-15-2023, 07:28 AM | #7 |
I think I have two (2) plugs on my AC box, but do not see a resistor. Ill look tonight, any pics of where this would be?
09-15-2023, 08:25 AM | #8 |
you cant see the resistor only the plug without removal. 2 Screws after you unplug it. Looks like a toaster element once you get it out,
09-15-2023, 08:46 AM | #9 |
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
09-18-2023, 07:18 AM | #10 |
thanks, will look into that
