Old 09-14-2023, 07:41 PM   #1
Chevy nutcase
Chevy nutcase's Avatar
Hotter makes it cooler
When I got my 66 c10 it was bone stock and the temp gage didn't work. When I cleaned and painted the motor I replaced the faulty sensor with a new one and I replaced the old crusty thermostat with what they had on hand, a 160°. I thought it might help it run cooler but now that the gage was working it always seemed to run hot. It never overheated but it would hit the H and with a laser thermometer on the water neck I knew it was running around 190° - 195°. I was told it's not so bad if it stays there but I still didn't like it. When I got it inspected I told the old guy who owned the shop what I did and he said put a 180° in it because the coolant is moving through the rad to fast. I heard that theory before but hearing it from him affirmed my actions. I got a 180° and voila it stays much cooler.
Chevy nutcase is offline   Reply With Quote
Old 09-14-2023, 07:47 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Hotter makes it cooler
That's good, and your engine will thank you for it in the winter time with better heat and defrost.
AcampoDave is offline   Reply With Quote
Old 09-15-2023, 12:18 AM   #3
Chevy nutcase
That reminds me. I switched out the blower recently because the old one sounded like a coffee grinder and now the new one only has high. I'm hoping the contacts in the switch are to blame
Old 09-15-2023, 09:13 PM   #4
AcampoDave
AcampoDave's Avatar
Maybe that rehostat transducer gizmoid with the coils on it that lives in the metal heat/defrost diverter
Old 09-16-2023, 07:47 AM   #5
Chevy nutcase
The whatchamacallit doodad? Lol please elaborate
Old 09-16-2023, 09:28 AM   #6
AcampoDave
AcampoDave's Avatar
https://67-72chevytrucks.com/vboard/...+thread&page=7 look at post #175
Old 09-16-2023, 11:59 AM   #7
Chevy nutcase
Thank you for making me aware of this component that I may be lacking or never had. Maybe 6 months ago I switched out the heater core and blower at the same time and I never encountered that resistor spring thing. The old blower even tho it sounded like a garbage disposal with rocks in it it had hi and lo speeds. This new one from LMC was identical. One pic is the blower motor under the hood and the other is inside the cab where the orange wire powering the blower connects. If that doohicky is inside the duct then I can live with just hi lol
Edit after reading further into the page you linked I wonder if the fan I got from LMC is just a single speed fan. If so they had no indication of such
Old 09-16-2023, 03:15 PM   #8
AcampoDave
AcampoDave's Avatar
Following the wires from the switch should lead you to it. Where that plug goes on your "in the cab pic" should be it. The little springs get hotter than blazes when they do their job so they put them in the path of the air flow. They are also very fragile.
