GMC vin decode
I was given a 64-66 GMC for scrap im trying to decode the vin to determine what year it is.any help would be appreciated
1965 chevy short bed step side "angel" 366 bbc/th-350 auto 1999 gmc sierra "terra" 350/4l80e 1983 pontiac firebird "kat" 350 lt-1 paxton supercharger/t-5 5-speed |
![]() Join Date: Dec 2009
Re: GMC vin decode
What is the Vin?
There are several decoders online.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Re: GMC vin decode
Edit : This is for Chevy
If it just the year you are looking for. The first digit in the VIN is the last digit of the year. 0=1960 1=1961 2=1962 3=1963 4=1964 5=1965 6=1966
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 09-16-2023 at 04:49 PM. Reason: Info for chevy |
Re: GMC vin decode
A couple pics of this works lol
Re: GMC vin decode
We have rain in the area I am still searching.
So my internet is in and out. The best link will not open for me Link:http://www.6066gmcguy.org/VinNumber.htm The 2503 I think is a Cab and chassis. P= Pontiac The B= 7000 lbs.
Re: GMC vin decode
I found this for 1/2 ton and 3/4 ton. GMC.
Link: https://media.lmctruck.com/pdf/CBE/0008.pdf Have not found out the F6541 means.
Re: GMC vin decode
Unfortunately it wouldn't open for.me either
#8 | |
![]() Join Date: Apr 2009
Re: GMC vin decode
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
Re: GMC vin decode
That link is just for 1/2 and 3/4 tons.
I sent that about the same time he posted. This is the link that probably has or had the info demon79 wants. Link:http://www.6066gmcguy.org/VinNumber.htm
![]() Join Date: Feb 2011
Re: GMC vin decode
From using the Jolly site VIN info
2503 P F6541B 25 1 Ton Truck 03 133" Wheelbase P Pontiac, MI (GMC Only) F 1964-1966 8th through 12th Digit This is your truck's number off of the asssembly line.This is a personal production number and may be any combination of 4 - 5 numbers B 6,001 - 10,000 Code GVWR
MusicMan70 1961 GMC Suburban |
Re: GMC vin decode
Thank you all for the help. I was hoping to find out what year it is so that I could possibly see about getting a title for it
![]() ![]() Join Date: Apr 2012
Re: GMC vin decode
As stated above the only thing a GMC vin tells you is F for 1964-1966 as a year. But , 1964 GMC VIN tags were still spot welded . 1965 GMC VIN tags used round rivets. 1966 GMC VIN tags used Rosette rivets . You have a 1965 GMC . There's other clues to the year but much more Indepth, like engine casting dates and trans and axle dates . Safe to say its a 65 by your VIN picture.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#13 |
Re: GMC vin decode
One more thing , GMCs can be titled differently as many of these GMC trucks were titled " The Year it Sold" instead of the year manufactured . Chevrolet did not do that. Evidence of this has been found on numerous trucks but still somewhat uncommon .
#14 |
Re: GMC vin decode
Thank you for the info I greatly appreciate it. I think I'm going to look into getting a title for it. I think it would be an awesome dually pickup
#15 |
Re: GMC vin decode
You can tell the year by the production number, for the 2500 the first series 1964 started with P-F1001 and H-F1001*, the second series 1965 P-F6001 Z-F2001 and the third series 1966 P-F12001 Z-F4001.
*The Oakland plant (H) closed in late 1963 after the F model series went into production. They move to Fremont (Z). the production numbers did not start over. |
#16 |
Re: GMC vin decode
Thank you. Everyone has been very helpful
