Old 10-05-2023, 10:39 AM   #1
truckin 79
Proportioning valve metal line
So I need to change the metal line going to drivers caliper. I buggered up the flare nut, what a suprise that never happens to me. Some word of advice for anyone else doing this, remove stamped 15/16 nut first, it is much easier to get to flare nut and get some leverage pushing it towards caliper. I used a crows foot to try and get line off in-between frame rails and rounded it off. Anyway I bought some metal brake line to bend up my own line. I am wondering if it is easier to just try and do where proportioning valve is or pull prop valve out slightly. I am just going to cut old line as close to flare nut on prop valve and use a ratchet. How hard is it to pull prop valve out slightly? What was GM thinking putting proportioning valve underneath the bottom of radiator?
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
