Old 10-25-2023, 02:08 PM   #1
Nanook
Nanook's Avatar
Auto column parts questions
Hello all! I have a few questions. Do any of the parts suppliers make the original type linkage and brackets for a 64 - 66 C10 with a factory auto on the column. I have the original column but I am missing all the other components. Secondly was the original powerglide a long or short tail-shaft?
Nanook is offline   Reply With Quote
Old 10-26-2023, 10:12 AM   #2
60-66
60-66's Avatar
Re: Auto column parts questions
There's several different styles of linkage used from 63-66 so if you want exact , need to be more specific , it has to do with the frame bracket mainly but any 64-66 linkage will work. 67-70 PG linkage will work as well. The PowerGlide cross shaft is unique to that transmission so TH400 linkage is different. All powerglides of this era are short shaft .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 10-26-2023, 12:32 PM   #3
Nanook
Nanook's Avatar
Thanks for the response...the column is out of a 66 C20 and will be installing in a 66 C10. Not sure what the transmission is out of, possibly a 63 car. Is there aftermarket linkage available that anybody may know of? I have seen aftermarket kits that require changing the shifter shaft so that may be an option.
Old 10-26-2023, 02:29 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used the Locar shaft kit.
https://www.summitracing.com/parts/l...iABEgJskfD_BwE
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-27-2023, 02:15 AM   #5
64shortbox
64shortbox's Avatar
Or you can save $60.00 bu getting this Lokar knock off for $30.00 on eBay. That's what I did.
https://www.ebay.com/itm/35467667808...Bk9SR5L0kPztYg
64shortbox is offline   Reply With Quote
Old 10-27-2023, 01:05 PM   #6
Nanook
Nanook's Avatar
Thanks all for the info, but not sure these will work with the powerglide as the shifter shaft is welded on.
