Old 01-10-2004, 04:01 PM   #1
canso
A/C crank pulley part numbers
I need to order pulleys for a small block with air. Does anyone have the part numbers for the crank pulleys. I think that there was two stacking pulleys. I'm not sure if it is suppose to be a single then a double or a double then a single. I hope someone can help with these numbers. Thanks
canso is offline   Reply With Quote
Old 01-10-2004, 04:36 PM   #2
JimKshortstep4x4
Talking
71 AC pullies for sbc, short water pump setup. Pullies are both stamped metal. Double pulley next to damper, PN 3744043BA
Single outside pulley that nests into the double pully, PN 3751232.
Earlier cast pulley setups have different spacing.
Jim
Old 01-10-2004, 04:44 PM   #3
rage'nrat638
rage'nrat638's Avatar
wow....so whats the water pump pulley PN....
SO I CAN MAKE SURE I HAVE IT
rage'nrat638 is offline   Reply With Quote
Old 01-11-2004, 01:56 PM   #4
canso
water pump puley number, does anyone have the part number. When I bought an a/c belt from gm for this application it was to long. I'm wodering if I have the correct water pump pulley. I have the same crank pulleys as numbers above.
Old 01-11-2004, 08:49 PM   #5
JimKshortstep4x4
Talking
Here is the water pump pully number that I have:
PN 1235778
It is a double stacker.
Jim
