Alternative AM Radio Source
Was wondering if other GM vehicles have the correct size to fit our radio location. I have an old private yard by me that has a lot of older GM vehicles just sitting for decades. Thought I would approach the owner to see if I could find one that might fit. Just trying to fill the empty hole..thanks
71 C-20 07 Magnum RT AWD |
![]() Join Date: Apr 2016
Re: Alternative AM Radio Source
It would be easier to get an old 67-72 truck radio from eBay or this forum, but then I'm taking the easy way. It's hard enough to get things right when working around in those tight places under the dash. If you enjoy that kind of tinkering you could probably just measure the face plate hole and distance between the knobs, and then go looking in the junk yard. You will probably need to do some fabrication on the mounting as mentioned by our friend body bolt in that recent thread about the bowtie radios. In any case you may want to get a small can of Deoxit D5 from Guitar Center or online, so you can get the old crusty radio working, that's what worked for me on my eBay radio. That is if you want it working. My goal is to get everything working, and even if I would rarely turn on the AM radio I want it to at least work when I turn it on. This week I spent getting the windshield washer working again after probably 40 years of broken.
I don’t listen to the radio in my daily driver much less this pickup, just want to fill the space. Right now I have the radio missing along with both the lighter and heater controls.
![]() Join Date: Dec 2009
What about a Radio Delete plate?
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() Join Date: Feb 2002
With the unreal high prices for Radio Delete Plates, that's probably the economy option.
When I bought my Orange Stepside in 1973, the PO had popped in an AM radio from an earlier GM vehicle. I don't recall if it had pushbuttons for stations, but it worked -- sort of. The antenna coax was draped around the dash. A sheetmetal screw held the pot metal radio in place -- if somewhat cockeyed. Speaker was crap. For a long cross country run back home from Cherry Point, NC to Tucson, I splurged on a big speaker from Radio Shack. In '77, after getting out of the military, I had a dude [supposed expert] install a Sanyo AM/FM/Cassette Recorder in the dash. Also 5'' Jensen speakers in the doors.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-20-2023 at 03:43 PM. |
#6 | |
![]() Join Date: Jul 2003
![]() Quote:
Obviously 1967-72 trucks, Blazers Suburbans 1967-77 GM vans 1961-64 Full-size Chevrolets
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
![]() Join Date: Dec 2012
Not the purist approach, but I made a delete plate to match my bed wood. Dash was already cut, so I made this to fit a billet radio mount frame.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
![]() Join Date: Jun 2022
I posted a link in that Bowtie radio thread that shows dimensions of various GM radios, so you might be able to match the hole you're trying to fill to some year+model combinations using that reference.
Hope this helps |
There's been a non-original AM radio in the dash of my '72 K2500 since I've owned it. It had chrome knobs and says Sonomatic in script. Those were in Buicks
