Old 11-22-2023, 12:15 AM   #1
TR32
TR32's Avatar
Tri-Five Header on 67-72 C10
I have been wondering for some time if anyone has tried using SBC headers meant for 55-57 Chevy{Car} on their 67-72 C10?
SUM-G9103 headers are a set I am specifically asking about.
I am running a 350/700r4, custom engine and tranny mounts, and is set back about as far as possible without firewall mods.
Thanks in advance!
1969 C10 SWB, 68 Front Clip, Tired azz 350 w/built 700R4, 3.73 Peg Leg...........
TR32 is offline   Reply With Quote
Old 11-24-2023, 01:06 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Tri-Five Header on 67-72 C10
I think that you will have a problem with the front tubes contacting the eng mounts or cross member under the engine? If you look in summits site,under headers for you truck (67-72), Hooker comps ( HOK-2452 HKR) you will see an example on how the front tubes go over the top & drop to the center & rear for clearance up front. These headers fit nice & tuck up pretty good. the collectors hang just about 2 - 2 1/4 inches below the frame rails. If you can post pics of your mounts.....some others may have suggestions Longhorn (the crazy fab nut)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
