11-26-2023, 02:07 PM | #1 |
stock Tilt column with a 700R4 question
Is anyone running an original 69-72 truck TILT column with a 700R4 overdrive?
im curious if there are any problems with the detents in the steering column? were there any mods needed to the column? |
11-26-2023, 02:24 PM | #2 |
70+ ( Old Skool Club )
Re: stock Tilt column with a 700R4 question
I am and the only thing is that you won't be able to put the trans into first gear unless u get a kit, I used a Lokar, which now that I got it don't think wa worth the expense.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-26-2023, 02:39 PM | #3 |
At the body shop.
We extended this for a recent 4L80 swap to get 1st
" That didnt make it any newer " " Dont antique the equipment " |
11-26-2023, 02:44 PM | #4 |
Ok, thanks for the quick replies. i am OK without first gear. as long as it still locks into park and i can bump it between neutral and drive without having to pull the lever toward me.
11-26-2023, 03:45 PM | #5 |
I'm not trying to be a dick (don't ask my wife) but do the KQQL mod so you can use 1st. There may be a scenario where you'll miss not being able to lock it in.
