11-29-2023, 09:37 PM | #1 |
Junior Member
Smell of gas in the cab
Hello all, new to the site and I’m looking for some info.
My son has a 1972 V8 Auto C10 with EEC and the smell of gas in the cab. The 1st thing I am going to try is replacing the fuel sending unit gasket and all the rubber hoses that are connected to the gas tank. The fuel sender for my truck has 2 hoses that go to it, one is larger than the other. I assume the larger one (supply) is 3/8 inch not sure what size the smaller one (return) is? The trucks fuel tank also has 2 rubber hoses on the passenger side (EEC) and 1 rubber hose on the drivers side that goes to the fuel neck. These hoses look all the same size. I assume they are 3/8 Inch? Can anyone confirm if my assumptions are correct that they are all 3/8 inch? Also does anyone know the size of the smaller rubber hose for the return on the fuel sender? |
11-29-2023, 09:52 PM | #2 | |
Re: Smell of gas in the cab
I don't remember what the return line is, my truck doesnt have one. Seems it was smaller, 5/16" seems right, but not sure.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-29-2023 at 09:58 PM. |
11-29-2023, 09:57 PM | #3 | |
Junior Member
11-29-2023, 11:30 PM | #4 |
That's 3/8" fuel hose as well. Seems that's so the tank doesn't get too full, not sure.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-02-2023, 03:48 AM | #5 |
71chevyshortbed402 is giving good recommendations IMO. Though, myself I would leave the stock sending unit if it is working. No doubt the Chinese replacement is not the same quality as the stock one. The line that goes to the fuel fill is a vent line that allows air to purge while filling.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-02-2023, 12:55 PM | #6 |
If you use the stock sending unit I would replace the fuel strainer on the bottom. When I pulled my sending unit the strainer was collapsed and fell off into the tank. That's a pisser. I was changing out the tank anyway. Looked like the sands of Iwo Jima in the bottom. On another side note. For years I could sometimes here something rolling back and forth inside the tank when cornering. Sounded like maybe a nut or something like that. When I removed the tank I looked for it. Nothing there. Aliens?
12-02-2023, 03:50 PM | #7 | |
Replace the rubber gasket regardless, it might be the very reason for the stench.
12-04-2023, 04:36 AM | #8 | |
12-04-2023, 02:21 PM | #9 |
Nope. The strainer fell off as I was lifting the unit through the hole. I thought about someone messing with me and putting something in the tank, but always had a locking cap. You know. Like putting gravel in hubcaps, anti seize on door handle, long wire tie on drive line or a chicken in the back of a service van over the weekend. Not that I would know anything about these. Anyway the mystery sound is still part of the X Files.
12-04-2023, 08:22 PM | #10 |
I have a '68 C/10 Stepside with the stock in-cab tank.
No EEC. The tank was replaced with a 1967 MY Tank in 1999 because the [then new] unleaded gas was dissolving bottom sediments and clogging my carb. Also the filler neck was chewed up when my locking gas caps key was lost, and had to be forced open. The '67 tank was identical and after a good hot tanking and thorough cleaning, worked great until about 2022. Then the brass float ball sank and was replaced with the Plastic Jeep float. However, in taking off the tank's lock ring with a brass drift punch, I accidently broke the gas gauge terminal loose from its bond. I replaced the Sender with a used one my pal, Pat Moreland sent me, but I used the original rubber seal ring. Resulted in gas fumes. Especially after filling the tank with 20 gallons +. I replaced the gasket with a new one from LMC, but I still got fumes in the cab. I replaced the 10 - 12'' hose under the cab that links the fuel tank output to the fuel line to the fuel pump. Still getting fumes. Is there an RTV type sealant that will seal off around that big O-Ring gasket?
12-05-2023, 02:58 PM | #11 |
The LMC gaskets are pretty thin. Don't know about others. Try 2 gaskets together. Maybe the locking ring isn't completely flat. Just a thought.
12-05-2023, 04:59 PM | #12 | |
The gaskets are ~2'' O-Rings [with a short tail] so you could not double stack them. After my mishap with the brass drift punch, I bought the Gas Tank Lock Ring Tool, P/N:32-4145. Setting the Sender in the tank pocket is super easy with it. I can look more closely later, for a misalignment, but I'm pretty sure it went in right. Before the Float swap, with a Non-Venting gas cap, the pressure would go whoosh if you pulled the cap off too fast. Now I use a cas cap that breathes. EDIT: Here's a shot of the new lock ring in place. Gasket under it. Looks OK, but still getting gas fumes.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-09-2023 at 06:59 PM. |
12-07-2023, 09:32 PM | #13 |
Junior Member
Wanted to give an update. Today my son and I replaced all the hoses and the fuel sending unit gasket. All the hoses looked pretty old and the fuel sending gasket was very flat. The fuel sending gasket we used was made by Spectra (bought off Amazon) and was pretty thick. Will give it some time but hopefully the smell of gas will be eliminated.
When we pulled the fuel sending unit the sock filter was missing. Tried looking in the tank for it but didn’t see anything. Made a quick trip to Orielly’s to purchase a new sock. When we put the new sock filter on it was very loose on the supply line. Was afraid it might fall off so I got a pair of pliers and lightly squeezed on the sock filters metal ring to create a little friction with the supply line. Not sure what is suppose to keep the sock from falling off. I can confirm all hose sizes for a 1972 V8 with EEC. The 2 EEC hoses on the passenger side of the fuel tank were 5/16 inch The fuel sender supply hose was 3/8 inch and the return was 1/4 inch The hose on the drivers side from the tank to the filler neck was 3/8 inch |
12-08-2023, 12:55 PM | #14 |
Thanks for the update. The filter sock is supposed to be a press fit.
12-08-2023, 03:18 PM | #15 |
I have been following this closely as I recently replaced the sender in my original style tank. The truck has no EEC being a C/20 built in Fremont. I have a aftermarket vented cap and funny thing never had a gas odor issue ever. Seems that the EEC equipped trucks have more of a gas smell problem than ones without ?
71 C-20 07 Magnum RT AWD |
12-18-2023, 07:29 PM | #16 | |
A mechanic I used back in the day ran the vapor line to a fuel pump return outlet. Add a "vented" cap - no issues or stench. The difference is, when operational the EEC reduces pollution, and probably adds a pinch more MPG. I wonder how an operating EEC impacts engine performance, if at all? I don't know, seems the intake would welcome the contribution.
12-19-2023, 01:31 PM | #17 | |
01-09-2024, 07:03 PM | #18 |
Junior Member
Came back to the thread to update. The gas smell inside the cab didn’t go away with the new hoses installed. I thought maybe the problem might be the EEC hoses that run up the passenger side pillar. I thought maybe the hose in there was old and cracked at that is why it was smelling. I decided to cap all 4 of those connections to see if that would help and my son drove the truck around for a few days.
It made the smell worse, but it helped us see what the real problem was. It turns out the tank has a leak. One of the first things my son and I did was to see if the tank had a leak but we didn’t see any. I think the tank has had a pin hole leak since he bought it. I believe the tank was building up pressure because the fumes weren’t being routed out through the EEC lines. I think this caused the leak to get bigger allowing us to see the real problem. |
01-09-2024, 08:16 PM | #19 |
Something to think about...
I have a '68 MY with no EEC Frou-frou. I've replaced the Sender, the O-Ring. the belly hose, and the O-ring again, and I still get gas fumes. The old float sank after a side collision in 4/22. The old sender got damaged -- terminal stud lost its seal -- when I used a brass drift pin and small ball pein hammer. Fumes are strongest when tank is full. What do I look for to spot a leak?
01-10-2024, 03:00 PM | #20 | |
Junior Member
If you had a way of pressuring the tank it might be able to take a tiny leak and make it bigger so that it can be seen. |
