Old 12-03-2023, 06:31 PM   #1
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Project Cowboy Cadillac
Finally getting back with a Crew Cab like I have been dreaming off since i had to part ways with my 84 Crew cab diesel 8 years ago, I have a 82 GMC C30 Cab and chassie single cab that i was putting back together but that will be parts truck for this
I did some trades and got this 1981 Chevy Crew cab dually for very cheap
missing engine and transmission,
little back ground info
Came from Pomona CA back in 2005 was used as a hauler for a private drag racer that did alot of racing at Pomona drag strip, (alot of time slips, parking cards etc was found when cleaning out)
Was imported to Denmark for the Engine and transmission (454/400 and just spares. thats way the left Dually fender has been cut off as all the bolts are spinning and they dont fit in the container
Has been sitting in at a storage yard since 2005 and was sold in early 2023 to the guy a bought it from.
It was born a 1981 Crew cab Dually with a 350, AC, power steering, Power windows and locks, No gauges only idiot lights, No tilt or cruise and in Soild white and Tan interior with bench seats
Now has a 89-91 Front clip, Lowering springs in the front, I think the rears have had removed a few leafs and diffrent shackels too.
The Plan: This wont be a restoration Like David Freiburger says dont get it right, just get it running
Drive train
Cadillac 500 with a TH400, I have plans for Fuel injection and a 4L80 later
down the road, might try to save for an LS 5.3 or 6.0 insted
2 new fuel tanks and sendering units, (plans are getting the TBI tanks so its ready for EFI)
Rebuild the brakes and front suspension/steering and new shocks
all 6 wheels blasted and powder coated white and 6 new tires
want to lower it in the back, looking at switch suspension air ride with C-notch
Exterior
Mount the rear fenders and paint the left rear dually fender to match the truck
New Mirrors
New head lights, all 3 on the right is busted
source a new tail gate and rear bumper
Onboard Air tank for Service jobs
Fix the rust in the rockers and pop out the dents in the fender and doors
Interior:
Fixing the AC (hate vehicles with out AC)
Cruise Control, not sure how hard it is to retro fit a later tilt and cruise collum with the wiring and delay whipers or else im just going to find a aftermarket cruise set up
New seat covers
Tinted rear door glass (front tint are illegal her in Denmark)
Full gauge cluster with gauges insted for idiot lights and I have a Mint 89-91 Wood grain bezel thats going on as I cant stand the alloy one
New stereo, it has a 90s stereo with Amp and aftermarket speakers behind the rear seats but I want new speakers and bluetooth and hands free
This going to be a Service truck for my company (mechanic work shop) and Hauler for our Drift car
the 500 thats going in
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 12-10-2023, 05:36 PM   #2
GmtGmt
GmtGmt's Avatar
Re: Project Cowboy Cadillac
New Radiator arived friday, Was looking at a used OEM 3 row cooler but when the price was higher than a new aluminium rad I rather wanted a new one.
I have used these rads on other high horse power cars and never had a problem.
Rockauto Brake parts, new hoses, wheel cylinders, Caliber Rebuild kit, Tempsensor and some gaskets for the rear axle.
Still wating on a new Mastercylinder, Pads and Brake shoes
Did some cleaning and quick vacum
Found this old relic under the seat
Found this behind the rear seat, an old G&S Design Comp 150 AMP
Waiting on a few parts so i can get the Engine and trans put in
Thomas
Old 12-22-2023, 05:13 PM   #3
GmtGmt
GmtGmt's Avatar
Oldschool Belltech drop spindels
Engine and Trans are in, Lined up and boltede down, have to drill some holes in frame for front engine mounts but its in at sitting
Thomas
Old 12-25-2023, 06:15 AM   #4
LT7A
Cool! Keep us up to date. Where are you in Denmark? I'm guessing somewhere in Jutland.
Old 01-07-2024, 04:37 PM   #5
GmtGmt
GmtGmt's Avatar
Kalundborg, Sealand
Its Running and driving under its own power
https://youtu.be/9z6iC76YfOU
Driven around the shop under its own power for the first time in 19 years
Radiator Mounted, Heat core vacumed testet and passed, Holds coolent and no leaks.
Thomas
Old 03-29-2024, 05:38 PM   #6
GmtGmt
GmtGmt's Avatar
Update
I didnt replace the rear main seal before installing the engine sadly it started to leak quickly :/ Not a fun job to do in the truck
Outer Dually rims back from the paint shop just got to get the front ones done and then the inner 2
Bought a new carburator as the old Quadrjet wont work proberly and leaking
Drove it the 15miles from the shop home where it sat for a mounth waiting for a Drive shaft to be rebuild as it was shacking so bad at 30mph
New fuel tank for EFI and had to put it in the bed at home to get it back to the shop as old tank was full of junk
Found a used tail gate not perfect but can be used
New used front lower door cards as the driver side was trashed
New Rear Bumper and hitch as the old one is booger welded to the inside of the frame
Best off all EFI! got a very nice deal on a Holley Sniper setup that a friend didnt like on his hot rod so has maby 5hours of run time
[/url]
Mounted
Standalone Relay and Fuse box for Fuel pump, Holley and Eletric Fan.
HEI Distributor and New leads
Old tank removed
New Fuel Tank and in tank Fuel pump a Decent Walbro pump
New Fuel Pressure Regulator and EFI Fuel Filter
Thomas
Old 04-01-2024, 10:43 AM   #7
GmtGmt
GmtGmt's Avatar
Thomas
