12-09-2023, 01:35 PM | #1 |
Junior Member
Seat belt removal
I dont know if these seatbelts are original but regardless does anyone know how to get the plastic cover off so I can get to the bolt, I assume it just pulls off but it doesnt seem to want to budge and I dont want to force it and snap anything. Thanks
12-09-2023, 02:07 PM | #2 |
Re: Seat belt removal
Grab it firmly down low and wiggle it back and forth while pulling upwards slowly and carefully is your friend.
71 C-20 07 Magnum RT AWD |
12-09-2023, 02:11 PM | #3 |
Suggestion, remove the seat, you will have to soak the bolts from above and below to have any luck removing them. PB Blaster is great, Or Kroil Oil. Took me a whole day to get mine out to install shoulder belts.
12-09-2023, 02:14 PM | #4 |
Also the bolts have a very thin head on them. I used a swivel attachment and made sure I held the socket in line with the bolts. It’s a challenge for sure.
12-09-2023, 02:19 PM | #5 |
Junior Member
Thanks guys
12-09-2023, 04:47 PM | #6 |
The Older Generation
Before you try pulling the cover off heat it up with a hair dryer on the low setting or you may crack it...... LockDoc
