![]() Join Date: Apr 2007
Factory 12 bolt posi question
Just converted my 3 speed to a turbo 350. As I was wrapping everything up and and the truck was on the lift, I put the truck in gear and pressed the brake firmly but the right rear wheel was spinning.
Question, how would only one whee spin on a posi? I’m hoping it’s just a brake issue (cylinder, adjustment, leak…) in that back rear wheel. I will say the brakes don’t feel right, like they did before I did all the work. The pedal is almost bottoming out when I’m completely stopped. TIA |
![]() Join Date: Aug 2015
Re: Factory 12 bolt posi question
I can't comment on your possible brake issue, but one reason for a posi to behave like a non posi is if there is an issue with the clutches. I did not know I had a posi until I pulled the cover and chunks of clutch plates fell out. I had used the spin the wheel test prior to finding/fixing that and I thought I had a one legged axle.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
#3 | |
68 C10 Longbed
![]() Join Date: Sep 2006
![]() Join Date: Mar 2007
Sounds like you have a brake problem first. Pull the right wheel and drum and inspect the shoes and hardware. I would pull the left also. It may be worn out if it’s the only one working.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
![]() Join Date: Jul 2003
The factory "posi" is a limited slip, not locker(NO-SPIN 20-30 series) unless stated as such on the SPID. There will be slippage under certain conditions.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Thanks everyone. I changed t he gear oil yesterday and it looked great inside. Drove it home on the freeway and it cruised great.
Up in the air I spun one and both spun the correct direction. I used maps 80-90 gear oil and added the additive they told me. I’ll start with checking the brakes Thanks |
#7 | |
68 C10 Longbed
