Back from the dead & Alcan Leaf Springs
I'm back from the dead, I think. Haven't spent much time on here in years! Looks like you're all still at it. Happy 2024! My truck is 52 years old now.
Still have the K10. Toyed around with a 76 Trans Am for a while but just sold it last week. The truck was the keeper. Might use some of the T/A proceeds to improve the K10. Anyone use Alcan springs for a factory-height K10? I've got Alcans on my Tacoma camper rig, and they're great. And I've seen them on lifted K-series trucks. But no stock-height examples, and I'm due for springs/shocks. ...and, here's a photo of the rig because we all like photos. I need some new photos! This one is several years old.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
The Older Generation
Re: Back from the dead & Alcan Leaf Springs
Welcome back, Good to see you posting again! I will follow along and see if there is any info posted about the Alcans. LockDoc
![]() Join Date: Sep 2014
![]() Join Date: Mar 2013
I've used Michigan Truck Spring with good results for stock height leaf springs on a couple of occasions and been very happy with the service, price, fit, finish, and ride. Call them and tell them what you're looking for. No affiliation.
www.truckspring.com |
#5 | |
All about them K’s
![]() Join Date: Jun 2014
I’m pretty sure Pete has a set of stock height Alcans on his K20 and maybe his blazer too.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Detroit Spring has been around since the beginning . They can build you a duplicate of your original or design to your specific request…
71 C-20 07 Magnum RT AWD |
Active Member
![]() Join Date: Jun 2018
I don't have a K10 -- so there's that. But, I'll share my experience for what its worth.
In June of 2023, I purchased rear leaf springs from Alcan for my '71 c2500. I asked for a 1-inch lift over stock, base spring rating (2000lbs), and for the pin to move 1/2" rearward. What I got was a 6-inch lift. My rear fender height went from 34.75" with the "old" springs, to 41" with the Alcans. I don't know why my particular situation ended up that way. I can only assume my springs were original to the truck; they sure looked old, and were a correct 2-stage 5-leaf pack. Maybe they were just really, really shot, so I grossly underestimated their existing sag, but maybe they had been taken from something else years before my ownership. I asked Alcan about it, and besides them asking if I installed them incorrectly (I didn't--not sure how you would anyways), there wasn't much to be done. I put in 2" drop shackles, removed one leaf, and now it sits at about 37.75". I've put a few thousand miles on it since then and hauled a few loads of gravel so I'm pretty sure this is where they are settling. The Alcans are noticeably tighter than my OE springs -- kind of makes sense though, given the OE ones were likely shot, and again, are a 2-stage design, unlike the Alcans. I am happy with the end result however. Still rides like a sofa, but now sits like a spry young truck instead of an old, tired one.
1971 Pontiac Firebird 1971 GMC C2500 |
#9 | |
Good to see your name back. still wrenchin' on mt. bikes? I enjoyed the ride I took in it all those years ago. Sweet truck!
I use local spring shops for stock spring work. I know Alcan springs are custom and known to ride far better than off the shelf lift springs. You do pay a good bit extra for that. I don't know what they could do any different to make theirs ride any better than stock minimal leaf semi-elliptical negative arch springs for all that money.
Carpe manana
![]() ![]() Join Date: Dec 2010
I have stock height, zero-lift Alcan springs on the K20 and K5 as Tyler mentioned. No complaints. US made, US steel and a nice ride.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#12 | |
Alcan is regional-local for me, so that's one reason I used them for the Tacoma. But yeah, they can be expensive. One of their methods is more thinner leafs vs fewer thicker leafs for any given ride height/load rating. Thought maybe that would provide a better ride than stock replacements from Summit.
#13 | |
Also, what shocks are you running? Many of the ones I've looked at that are nicer seem to be intended for lifted applications, not stock-height. I know this truck will never be SMOOTH, but I'm pretty certain I can improve on the worn out, stock leaf springs and ancient shocks.
#14 |
Carpe manana
Good to see you back. The owner at the time, Bill, had all the OE specs and knew what to assemble. As an aside, these specs are in old 67-72 GM parts manuals. Ride quality was much improved over the old original springs. I placed lengths of teflon leaf spring liners between the perches and the spring packs and recommend that. Essentially, I was replacing the plastic liner the GM had in place at this location.
As for shocks I run GM Pleasurizers. I was able to find NOS examples. Work great with HD examples on the K20. Also used matching Pleasurizer steering dampers
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 01-04-2024 at 10:53 AM. Reason: added |
#15 | |
Active Member
Kind of a bad photo but like I said, I'm happy with it. Rear end sits 2 inches higher than the front so I can load it up and it doesn't get all saggy, and I think it's right on the edge of looking weird when unloaded. To each their own, however.
